FOR Loop Problem
Hi
I hope this is the right section for my Problem. I wrote this Code:
int pz;
                        for(int zahl = 50; zahl < 500; zahl++)
				for(pz = 0; pz > zahl; pz++);
                                        Serial.println(zahl);
					Serial.println(pz);
                                        Serial.println("\n");
					delay(50);
Via Serial I got this wit this Program:
50
0
51
0
52
0
53
0
54
0
55
0
56
0
57
0
58
0
59
0
But I like to get something like this:
50
1
50
2
50
3
50
50
51
1
51
2
51
3
51
51
52
1
etc etc etc.
But I can’t find my wrong part of the Code. I don’t know how I can fix that.
Berkutta
I presume you want to do
for(pz = 0; pz < zahl; pz++);
Yeah. But now it stays on the value.
50
50
51
51
52
52
53
53
54
54
55
55
56
56
57
57
58
58
Hi, try
Tom… :slight_smile:
Also select TOOLS and click Auto Format.
Removing of the Semikolon did the whole trick. Wow! Thank you!
So the next Problem is here. I want to divide the variable zahl (integer) through pz (integer). But I only get a weird result in a float variable without koma provides.
int pz;
float rechnung;
      Serial.println(pz);
      rechnung = zahl/pz;
      Serial.println(rechnung,3);
      delay(0);
The first is zahl, second pz, and the last should be the rechnung float. But I only get .000 and I don’t know why.
58
9
6.000
58
10
5.000
58
11
5.000
But I only get .000 and I don't know why.
Because C does the int division first and then assigns it to a float.
If you want to do float arithmetic you have to cast them as floats first like this:-
rechnung = (float)zahl/(float)pz;
Why all the blank lines in your code?
Now everything works great. Thank You!
