For loop question - Simulating a robot' s movement on a 2d array
Hi, i' m trying to simulate a robot' s movement on a 2d array. In my case, robot goes forward firstly, if it sees a engel, it turns left and continues its movement. The problem is that, i could not present turning left and moving on left-direction on the initial matrix.
Here' s my code:
#include <Servo.h>
#define x 7                                         //Matrix dimensions
#define y 7
const int trigPin = 12;
const int echoPin = 11;
Servo myServo;                                     //variable definations
Servo myServo2;
int pos = 0;
int counter;
int counter1 = 0;
int counter2;
int counter3;
int integer;
int integer2;
int integer4;
long duration;
long distance;
  myServo.attach(9);
  myServo2.attach(10);
  pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
  int my2dArray[x][y] = {                          // initial matrix
    {1, 1, 1, 1, 1, 1, 1},
    {1, 1, 1, 0, 1, 1, 1},
  // Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance= duration*0.034/2;
  int robot = my2dArray[3][3];                   // first place of robot
  if (counter1 > 0 ) {
    for (integer = 0;  integer < counter1; integer += 1) {
      if (distance < 10) {                                  //seeing the object
        for (pos = 0; pos <= 180 ; pos +=1){                //turning left
          myServo.write(pos);
        for (pos = 0; pos <= 180  ; pos += 1) {            //moving on after turning
          myServo.write(pos);
          myServo2.write(pos);
          if (pos == 180) {
            counter3 +=  1;
        Serial.println(integer);
        for (integer4 = 0;  integer4 < counter3; integer4 += 1){      //modifying matrix if there is an object
        my2dArray[3 + integer][3+integer4] = robot * my2dArray[3 + integer][3+integer4];
        Serial.println("Break condition.");
      else {
        my2dArray[3 + integer][3] = robot * my2dArray[3 + integer][3];    //modifying matrix in case of there is no object
  for (integer2 = 0; integer2 < 7; integer2++) {                          //displaying matrix
    Serial.print(my2dArray[integer2][0]); Serial.print("|");
    Serial.print(my2dArray[integer2][1]); Serial.print("|");
    Serial.print(my2dArray[integer2][2]); Serial.print("|");
    Serial.print(my2dArray[integer2][3]); Serial.print("|");
    Serial.print(my2dArray[integer2][4]); Serial.print("|");
    Serial.print(my2dArray[integer2][5]); Serial.print("|");
    Serial.println(my2dArray[integer2][6]);
  for (pos = 0; pos <= 180  ; pos += 1) {                               // moving forward as first movement
    myServo.write(pos);
    if (pos == 180) {
      counter1 +=  1;
The problem part is:
"integer" value does not change in the problem part, it' s always 0 in despite of the first for loop. How can i pass the "integer" to the problem part properly?
