The following code excerpt is from a HX711 (24-bit ADC) library that seems to be fairly popular (e.g., first hit from Google search on “HX711 Arduino library”).
It is supposed to read in 24 bits of data from the HX711. I don’t understand how it can work at all.
The data array has three elements, but the for loop starts with index j = 3 (should start with 2). The XOR and “return” statements have it right (use data[2] for the eight most significant bits), so it seems that the eight most significant bits are lost (and written somewhere in memory where they shouldn’t be).
The decrement code is in the for loop header “condition” position. Is that a valid use? How many times would for (byte j = 3; j– loop?
The ^= (XOR) compound operator is not in the Arduino reference page. But I guess it works.
The XOR compound operator strips the leading zero from the result. What’s the purpose of that? Doing that would change what should be a negative 8,388,608 (1 followed by 23 zeros) to zero, or would change a negative 1 (24 ones) to positive 8,388,607.
long HX711::read() {
// wait for the chip to become ready
while (!is_ready());
byte data[3];
// pulse the clock pin 24 times to read the data
for (byte j = 3; j--;) {
for (char i = 8; i--;) {
digitalWrite(PD_SCK, HIGH);
bitWrite(data[j], i, digitalRead(DOUT));
digitalWrite(PD_SCK, LOW);
// set the channel and the gain factor for the next reading using the clock pin
// not pertinent to forum post, except that the for loop here looks correct :)
for (int i = 0; i < GAIN; i++) {
data[2] ^= 0x80;
return ((uint32_t) data[2] << 16) | ((uint32_t) data[1] << 8) | (uint32_t) data[0];
Thank you. Hmm. I think I get it: j starts at 3, but when the so-called "condition" (j--) is first evaluated, it decrements j to 2. So we enter the first loop with j=2, as it should be.
But after the second loop finishes, with j=1, then the "condition" (j--) = 0, which is false, so the loop should not execute again.
That is, the loop should execute only 2 times, not three. So it still doesn't seem right.
(I'm at work and can't try printing intermediate results...)
Set j = 3
Evaluate j (it's three, so true). Now decrement j
Execute loop body with j=2
Evaluate j (It's two, so true). Now decrement j
Execute loop body with j=1
Evaluate j (It's one, so true). Now decrement j
Execute loop body with j=0
Evaluate j (It's zero, so false). Now decrement j
Don't execute loop body.
