for Max/Jitter
Hi.
Do you have any plan for working Arduino borad with Max/Jitter in future?
I am just curious. :slight_smile:
Well arduino already works with MAX/Jitter :slight_smile:
You just need to use the serial port patch and send a stream of bytes to it.
I had an arduino board read an analogue joystick and send data to a Max/Jitter program as part of an exhibition that was running for 2 Months at the V&A museum in London.
The MAX code was written by the designer of the piece (Michal Rinott) therefore I don’t have a code sample to post
I’ll try to find an example to publish
massimo
I see. I guessed it might work with serial ports before getting this reply. :slight_smile:
Thank you very much. :slight_smile:
If you find that example, It would be great for me. :wink:
Actually, the Malmö group is going to host a workshop in Copenhagen specially for Vj’s and musicians who are using MAX or PureData. We expect to produce some nice examples during November. If you do it first … maybe you would like to pass by and play with us.
/DD
