Hi PaulS
Full code as it is is a bit long and messy I am not a coder but copy someone's and make it work VB Java QT4 and now C++
Thanks for Bits of copy Sketch From
Mega multple serial test
created 30 Dec. 2008
modified 20 May 2012
by Tom Igoe & Jed Roach
* OBD-II-UART Quickstart Sketch
* Written by Ryan Owens for SparkFun Electronics * Released under the 'beer-me' license
* 7/5/2011 if we ever meet then you buy me a beer
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
int a = 0;
int b = 0;
int c = 0;
int n = 0;
int m = 0;
int intmillis = 0;
unsigned long lastmillis = 0;
unsigned long PIDData = 0;
char inOBD=0;
unsigned long AHex;
unsigned long AHex1;
unsigned long AHex2;
int AHex2I =0; /// Speed-Map
int AHex2IT= 0; ///Temp
unsigned long AHex3;
unsigned long AHex4;
int AHex4I=0; ///RPM
int RPM=0;
int KPH=0;
int InjTorq=0;
int MAP=0;
unsigned long AHex5;
int AHex5I=0; ///Torque
char Torq[ ]=("EEEEEEEEEE");
char TorqT[ ]="vvvvvvvvvvvvvvvvvvvvvvvvvvvvvv";
int PidRead=1;
int InjOnVal=100;
int LastInjVal=0;
int LcdT=0;
unsigned long InjTot=0;
int MinInjOnVal = 2800;
int InjOffVal=5000;//set by A,B,C Below
int InjOffValA=4300;//1st responce val
int InjOffValB=4300;//2nd responce val
int InjOffValC=1110;//3rd responce val
int sensorValue0 = analogRead(A0);//TempReducing-560=11deg Road running 128
int sensorValue2 = analogRead(A2);//MapIncreasing-300to330=idel Max700
int INJ = 5;
int VSol = 7;
String MonRead;
int Mon=2;//???set as 1,2,3 to Monitor 6 No serial display
Serial1.begin(38400);//OBD-CanBus
Serial1.println ("ATZ");
pinMode(INJ, OUTPUT);
pinMode(VSol, OUTPUT);
digitalWrite(VSol, LOW);
digitalWrite(INJ, LOW);
// initialize both serial ports:
if (Mon != 6) {Serial.begin(9600); }//LapTop Read
lcd.begin(16,2);
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("YO, UniversE!");
while (Serial1.read() >=0);
Serial1.println("ATTP0");
//delay(1000);
//Serial1.flush();
//Serial1.println ("010C");
//delay(1000);
//while (Serial1.read() >=0);
lcd.setCursor(0,0);
lcd.print(" ");
lcd.setCursor(5,0);
lcd.print("RPM");//RPM
lcd.setCursor(5,1);
lcd.print("TOQ");//Torque
getConected();
delay(100);
Serial1.end();
delay(3000);
getConected();
delay(3000);
InjOnVal=0;
InjTot=0;
//RPM-Torque Values decide InjVal MicroSeconds
if (sensorValue0<=300){ //Vap Temp
digitalWrite(VSol, HIGH);
else {
InjOnVal=((InjTorq*InjTorq)*2.2);
InjOnVal=InjOnVal+(RPM-500);
if (InjTorq>=60) { InjOnVal=10000-(InjOnVal-8000);}
if (InjTorq>=80) { InjOnVal=MinInjOnVal; }
if (InjTorq<=20) { InjOnVal=0;}
if (RPM<=1200) { InjOnVal=0; }
if (RPM>=4000) { InjOnVal=0; }
if (InjOnVal<0) { InjOnVal=0; }
if (InjOnVal>(LastInjVal+250)) {InjOnVal=LastInjVal+(RPM*.1);}
if (InjOnVal>10000) { InjOnVal=10000; }
LastInjVal=InjOnVal;
LcdT=InjOnVal*.1;
c=0;
//if(Mon==1) {Serial.print(" ");}
if(PidRead==5) { PidRead=1;}
if(PidRead==1) { Serial1.println("010C"); } //RPM-PID
if(PidRead==2) { Serial1.println("010D"); } //Speed-PID
if(PidRead==3) { Serial1.println("0105"); } //Temp-PID
if(PidRead==4) { Serial1.println("010B"); } //Map-PID
if (InjOnVal>=MinInjOnVal) {
digitalWrite(INJ, HIGH);
}//inj1
delayMicroseconds(InjOnVal);
InjOffVal=InjOffValA;
getResponse();
if(Mon==1) {Serial.println(millis());}
}//inj2
InjOffVal=InjOffValB;
getResponse();
}//inj3
getResponse();
}//inj4
InjOffVal=InjOffValC;
getResponse();
c=0;
if (PidRead==4) { //Map
lcd.setCursor(9,1);
lcd.print(" ");
lcd.setCursor(9,1);
lcd.print(AHex2I);
MAP=AHex2I;
lcd.setCursor(13,1);
lcd.print("Map");
PidRead=5;
if (PidRead==3) { //Temp
lcd.setCursor(9,1);
lcd.print(" ");
lcd.setCursor(9,1);
lcd.print(AHex2I-40);
lcd.print("Tem");
PidRead=1;
if (PidRead==2) { //Speed
lcd.setCursor(9,0);
lcd.print(" ");
lcd.setCursor(9,0);
lcd.print(AHex2I);
KPH=AHex2I;
lcd.setCursor(13,0);
lcd.print("Kph");
PidRead=4;
if(PidRead==1) { //RPM
lcd.setCursor(0,0);
lcd.print(" ");
lcd.setCursor(0,0);
lcd.print(AHex4I);
lcd.setCursor(5,0);
//lcd.print("RPM");
lcd.print(LcdT);
RPM=AHex4I;
PidRead=2;
/*lcd.setCursor(10,0);
lcd.print(" ");
intmillis=(millis()-lastmillis);
lcd.print(intmillis);
lastmillis=millis();
c=0;
Serial1.println("0104");//Torque-PID
}//inj5
getResponse();
}//inj6
getResponse();
}//inj7
getResponse();
}//inj8
getResponse();
c=0;
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print(AHex5I);
InjTorq=AHex5I;
lcd.setCursor(5,1);
lcd.print("ToQ");
lcd.setCursor(10,1);
lcd.print(" ");
if (Mon==2) {
MonRead="";
InjTot=InjOnVal;
InjTot=InjTot*8;
MonRead=MonRead+","+ RPM+","+ InjTorq+","+MAP+","+KPH+","+InjOnVal+","+InjTot;
Serial.print(millis());
Serial.println (MonRead) ;
if (RPM<=800) {
getConected();
PidRead=1;
if (RPM>=4000) {
getConected();
PidRead=1;
void getResponse(void){
for (int a = 1; a<(InjOffVal); a++) {
if (Serial1.available()) {
b=b+1;
char inOBD = Serial1.read();
if ((b>8)&&(b<18)){
Torq[b-7]= inOBD;//Serial1.read();
c=c+1;
if (c>=14001){
//Serial.println ("Start-");
AHex1=strtol(&Torq[3],0,16);//Good for 1
//Serial.println (AHex1);
AHex2=strtol(&Torq[5],0,16);
//Serial.println (AHex2);
AHex2I=AHex2;
AHex2IT=(AHex2I-40);
AHex3=strtol(&Torq[8],0,16);
//Serial.println (AHex3);
AHex4=(((AHex2*256)+(AHex3))/4);
//Serial.println(AHex4);
AHex4I=AHex4;
AHex5=((AHex2*100)/255);
AHex5I=AHex5;
//Serial.println(AHex5);
if (Mon==2) {
String MonRead(Torq);
Serial.println(MonRead);
b=0;
c=0;
void getConected(void){
for (int m = 1; m<(5); m++) {
if(m==1) {Serial1.println("010C");}
if (m==2) {Serial1.println("010C");}
if (m>=3) {Serial1.println("");}
delay(5);
for (int n = 1; n<(10000); n++) {
// read from port 1, send to port 0:
b=b+1;
TorqT[b]= inOBD;//Serial1.read();
if (Mon==2){Serial.println(inOBD);}
if (Mon==2){Serial.println(n);}
String MonRead(TorqT);
if (Mon==2){Serial.println(MonRead);}
b=0;
I will cut it down to see if its something within the rest of the code affecting it
Thanks
