So, I am playing with a coin toss sketch where 2 LEDs turn on with a number generator acting like a coin toss. Now I want to count when tails land. I tried an if statement, but it only showed tails as a 1, heads as 0 on the serial. I want it to count up. I have been trying to play with the sketch to get it to increment but no good. My computer is broke so I cannot up load sketch to forum sorry. Looking for an example if possible. I also looked at for statements, but not sure.
Bstanko6:
What you describe is a little hard to understand, seeing what your current code would be very helpful.
Bstanko6:
for statements are loops. How would you use it?
I saw this in for loop and thought it would be for increment ink. I could be wrong. Basically, I just want to count up every time tails lands on serial monitor.
Bstanko6:
For loops are for when you want your code to loop a specified number of times.
Variables are for keeping track of things like, how often something occurs.
int counter=0; // create a variable
if (Serial.available()) { // check to see if a serial character was received.
if (Serial.read() == '0') { // see if the user entered "0"
counter = counter + 1; // increment the counter variable by 1
Serial.print("Tails count: "); Serial.println(counter); // print out current value of counter
I'm going to try it. Thank you!
