Hi, I was hoping to tweak an existing force sensor resistor (FSR) project (Using an FSR | Force Sensitive Resistor (FSR) | Adafruit Learning System) by adding a second FSR so I can record measurements from 2 sensors. Do I need a second arduino board, or can I use one board to supply 5V to each FSR and then wire it up similar as in the linked project, with one FSR going into analog 1 and the second one going into analog 2? I am concerned that the resistance reading of one will affect the resistance of the other (and in turn the analog voltage) if I do not have them isolated from one another.
Also, if instead of sending the FSR measurements to the analog pins, is it possible to send the output voltage from the arduino board to a NIDAQ? Will it be in PWM? Thanks.
