I am attempting to save some inputs onto an SD card through the internet.
However, when I use two inputs the SD card will not open, it will work with only one.
In the code below if I comment out either
client.print ("");"
or
client.print ("");
The SD card will open and the uncommitted input will save to the file.
Has anyone else experienced this issue?
I am at a loss of how to fix it.
Arduino Uno V3
Seeed Ethernet Sheild V2.0 (W5200)
#include <SD.h>
#include <SPI.h>
#include <EthernetV2_0.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
#define W5200_CS 10
#define SDCARD_CS 4
//Login Information
char MyID[] = "123"; //Variable for Password
char MyPass[] = "123"; //Variable for Password
String buffer = ""; // Declare the buffer variable
String NewBuffer = ""; // Declare the buffer variable
int ValidID = 0;
//SD Card
File Login;
File Data;
//Analogue Ves
int buff[6];
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(W5200_CS, OUTPUT);
//disconnect the W5200
digitalWrite(W5200_CS,HIGH);
pinMode(SDCARD_CS,OUTPUT);
if (!SD.begin(SDCARD_CS)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
//start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
//Initialize Login Variable
ValidID = 0;
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
//buffer+=c;
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
while(client.available()) {
char UnPwrd = client.read();
Serial.write(UnPwrd);
buffer+=UnPwrd;
client.println("Content-Type: text/html");
client.println("Connnection: close");
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
if (ValidID == 0) {
client.print ("<form method=post>");
client.print ("User ID:");
client.print ("
client.print ("<input type=id name=id size=25>");
client.print ("
client.print ("Password:");
client.print ("
client.print ("<input type=pass name=pass size=25>");
client.print ("
client.print (" <input type=submit value=Login>");
client.print ("</form>");
if(buffer.indexOf(MyPass)>=0 && buffer.indexOf(MyID)>=0) {
ValidID = 1;
client.print("<meta http-equiv=\"refresh\" content=\"0\">");
buffer="";
if (ValidID == 1) {
client.print ("New User ID:");
client.print ("
client.print ("<input type=newwid name=newid size=25>");
client.print ("
client.print ("New Password:");
client.print ("
client.print ("<input type=newpass name=newpass size=25>");
client.print ("
if(buffer != "") {
Login = SD.open("Login.txt",FILE_WRITE);
if (Login) {
Serial.print(buffer);
Login.println(buffer);
Login.close();
Serial.println("New ID Added");
else {
//failed.
Serial.println("Error Opening Login File");
ValidID = 2;
if (ValidID == 2) {
client.println("<meta http-equiv=\"refresh\" content=\"5\">");
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
buff[analogChannel] = analogRead(analogChannel);
client.print(buff[analogChannel]);
client.println("
client.println("</html>");
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
delay(200);
// close the connection:
client.stop();
buffer=""; // Clear the buffer at end of line
Serial.println("client disonnected");
Serial.println("ValidID:");
Serial.println(ValidID);
Any assistance is greatly appreciated
