I had an issue: because of the power fluctuation and/or a thunderstorm, the SD card that I am using with ESP8266 was damaged: some file names became unreadable (FAT table broken?) and ESP couldn't do anything about these files which caused some issues.
I inserted the card to my computer and made a "Tools -> Error checking -> Check". The card was fixed and everything works fine since then.
Can you please advise if it is possible to avoid such kind of errors?
When I am using Arduino,
- Is there a way to figure out that the card is partially damaged (I think it's called checking the fat table)?
- Is there any way to make a card check/fix like the Windows does?
- Is there a library that can make a quick format?
Thanks.
