Formatting and refresh issues with 128x64 OLED screen
Hi again
I'm currently working on a little project creating a smart watering irrigation probably like lots of other no nothing jabronis during these covid times. My first goal is to get my display screen to accurately update without flickering. To do that I initialized the format in setup (don't mind the "xyz" placeholders I intend to replace them with actual variables) and intend to overwrite the variables as they update in loop, apparently so the whole screen doesn't have to refresh, eliminating flicker, which works. My current problem:
Because the decimal places change I need to erase what's behind the new value. I'm pretty sure from what I read the solution is to draw a rectangle behind it. So my questions are: Is this the best way to fix this? How do I draw a rectangle and what is the most efficient way to do it? (Least amount of code and libraries)
Thanks in advance I'm sure I'm going to have some hall sensor questions next week :slight_smile:
Harold
Arduino UNO
OLED 128x64 .92" generic 4 pin
float soilSensor1 = A0;
float VWC1;                                                     //Value returned from soil sensor
float sensorVoltage1;
#include "SSD1306Ascii.h"
#include "SSD1306AsciiAvrI2c.h"
#define I2C_ADDRESS 0x3C
#define RST_PIN -1
SSD1306AsciiAvrI2c oled;
  analogReference(EXTERNAL); // use AREF for reference voltage
  pinMode(0, INPUT);
  #if RST_PIN >= 0
  oled.begin(&Adafruit128x64, I2C_ADDRESS, RST_PIN);
#else // RST_PIN >= 0
  oled.begin(&Adafruit128x64, I2C_ADDRESS);
#endif // RST_PIN >= 0
  // Call oled.setI2cClock(frequency) to change from the default frequency.
  oled.setFont(Arial_bold_14);
  oled.clear();
  oled.print("12:00pm");
  oled.print("           ");
  oled.println("70F");
  oled.print("VWC: ");
  oled.print(VWC1);
  oled.println("%");
  oled.print("Last: ");
  oled.print("12:52");
  oled.println("hrs ago");
  oled.print("Total H20: ");
  oled.print("25556");
  oled.print("g");
  float soilSensor1 = analogRead(0);
  float sensorVoltage1 = soilSensor1*(3.0 / 1023);
  if(sensorVoltage1 <= 1.1) {                                   //Calculate Voltage and VWC of soil sensor on A0
    VWC1 = 10*sensorVoltage1 - 1;
  } else if(sensorVoltage1 > 1.1 && sensorVoltage1 <= 1.3) {
    VWC1 = 25*sensorVoltage1 - 17.5;
  } else if(sensorVoltage1 > 1.3 && sensorVoltage1 <= 1.82) {
    VWC1 = 48.08*sensorVoltage1 - 47.5;
  } else if(sensorVoltage1 > 1.82 && sensorVoltage1 <=2.2) {
    VWC1 = 26.32*sensorVoltage1 - 7.89;
  } else if(sensorVoltage1 > 2.2) {
    VWC1= 62.5*sensorVoltage1 - 87.5;
  Serial.print("Voltage = ");
  Serial.print(sensorVoltage1);
  Serial.print("   VWC = ");
  Serial.println(VWC1);
  oled.setCursor(36,2);
  oled.print(VWC1);
  oled.print("%");
  delay(50);
Nevermind I don't need to draw anything I just added a few spaces after "% " and it overwrote the older data. :slight_smile:
Hi.
I have been using an SSD1306 for a while and I use a different library. here is a couple of snippets from my latest foray. There is no flicker and it is very smooth.
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(128, 64, &Wire, OLED_RESET);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //or 0x3D
//The actual display bit.
  display.clearDisplay();
  display.setTextSize(2);
  display.setTextColor(WHITE);
  display.setCursor(0, 0);
  display.println("YOU");
  display.println("NEED");
  display.println("TO");
  display.println("SET");
  display.println("YOUR");
  display.println("PLACE!");
  display.display();
  delay(5000);
