forming a string for AdvencedSerial library
I am attempting to use the AdvancedSerial library "GitHub - renatoferreirarenatoferreira/ebl-arduino: Automatically exported from code.google.com/p/ebl-arduino". The onReceive serial string appears to work just fine. However I have not been able to form a proper string for the send method. I just don't understand pointers and arrays well enough. There is only a sample sketch using the :onReceive" method and not the "send" method. Does anyone have a simple sketch for preparing a string for the "AdvancedSerial.send" method of this class?
Jim
The send() method's signature is:
void send(byte id, byte size, byte* payload);
So,
byte id = 23;
char *msg = "Send this";
instance.send(id, (byte)strlen(msg), (byte *)msg);
Thanks! PaulS said
PaulS:
So,
byte id = 23;
Does the 23 mean anything or could I make the ID anything I want. I'd like the id to indicate which Arduino needed to perform which action.
Also I am totally lost! I have
string "Temperature: "
float "temp_f" which I want as string "xxx.xx" first x is ' ' or '-'
string "FHumidity: "
float "humidity" which I want as string "xx"
string "%"
Which I want to make into a long string, so I send "Temperature: xxx.xxFHumidity: xx%" to the other side. I have not been able to convert the float into strings like xxx.xx or xx! So what I want is:
id = destination address(A,B,C etc)-operation(1,2,3 etc) ie. A1 or C3
size = 33 ( always 33)
payload = Temperature: xxx.xxFHumidity: xx%
I new to C-C+ and pointers and arrays, am I in over my head? I'm getting a lot of errors so I need to tackle this a little bit at a time.
Jim
Not a thing.
Not even close. Post some real damned code.
dtostrf() to the rescue.
id is a byte. You need to be careful what you are trying to stuff into it. 0xC3 is not the same as "C3".
Yes, you do. If needed, post the code and the errors. This isn't rocket surgery. It just takes a little common sense to convert the values to the string you want.
