Forming strings from digitalRead input and comparing them
New member signing in! Hopefully this is the correct section to post and this hadn't bee discussed too many times earlier.
I have an Arduino Duo. My project is to make a small stand-alone ir-remote converter. I have a Bang & Olufsen audio system. I would like the converter to listen to the IR data, note when there is a command sent, capture a pre-set length of bytes and compare this to preset strings (=to identify certain commands). Then the program should react in a certain way (as a result, to send out another IR command to control another devices).
I have an external IR receiver from a B&O link room system that has a receiver and processor. It works on 5v DC that I supply from the Arduino. Data output is connected to a digital pin 2. When I send an IR command and keep reading the digital pin 2 I got a series of 0s and 1s depending on a command.
Fe. running this:
  pinMode(2, INPUT);
  int data = digitalRead(2);
  Serial.println(data, DEC);
I got stuff like this: 01111111101110110110110110110110111101100110110110110110 (with infinite number of 1s (it might be good idea to invert the read as 1 seems to indicate low now) before and after.)
How can I capture a string of the input? The commands are quite different and I wouldn't need many so comparing only the beginning of a command string (like 5-10 characters) should be enough. Or should I approach this in some other way? I will get on to the IR sending (fe. Apple Remote commands to control my MacBook) later when I get the receiving part working.
Typically you can use Shirriff's IRremove library to decode incoming IR signals. The IR is encoded in particular ways. You can directly read the encoded 0 and 1 but you can also get the decoded result easily from his library:
Hi. Thanks.
I did try the IRremove earilier but couldn't get it working for some (IDE) reason. The version you linked works. However the B&O remote codes are longer than what many other remotes use. When I run the IRrecord and capture a signal, I receive it in two separate parts as the code cuts it too early.
For example; I press CD on remote and serial monitor shows:
Received unknown code, saving as raw
m1450 s1650 m1450 s1600 m1450
m1450 s1600 m1450 s4700 m1450
When I try to send it out, it doesn't work(=control the music system) as the software sends only the last half of the original code. I will try flipping thrue the IRremote.h to see if there some useful variables.
Hi.
The Bang & Olufsen infrared receiver is very sensitive, meaning that it picks up a lot of noise. That is why it looks like the code cannot be in one buffer in the IRremote Library. Also the B&O infrared command uses biphase mark code, which is why the commands all look the same in the library.
However, a infrared command from the B&O remote only consists of 17 bits (1 bit for link, 8 bits for address and 8 bits for the command)
The data from the infrared receiver must be filtered in order to decode the actual command.
You can find my program for decoding the data from the infrared receiver on my Github account:
I am planning on implementing support for receiver's 4-key "keyboard" and 2 LEDs in a future version.
The decoder has been implementing using Timer1 so it should be possible to run the IRremote library "Beomote" library simultaneously.
If you have any questions, feel free to contact me at christian.lykke@gmail.com
There is no processor in the infrared receiver :wink:
