formula for points on a circle.
Hi All
I am looking for some help please. I am building a sort of cnc machine (not using GRBL)
I am looking for a formula that I can use to calculate the X and Y coordinates of points around a circle.
The information I will have is the radius of the circle and the number of holes centre of the circle will be at 0,0 X,Y.
I have tried using the rcos =X and rsin=Y but this does not seem to work unless I am doing it wrong (probably) .
Is there anyone out there that can help me please.
Bob
float r=0;
float radius=0;
float h=0;
float holes=0;
float j=0;
float i=0;
float x=0;
float y=0;
Serial.println("what is your Radius?" );
while (Serial.available()==0){}                                  //Wait for user input
   radius = Serial.parseInt();
   Serial.println(radius);
Serial.println("How many holes?" );
   holes = Serial.parseInt();
   Serial.println(holes);
j=360/holes;//convert holes to degrees per positon
i=j*3.14/180;//convert to degrees per positon radians
for (int k = 0; k <=holes-1; k++) {
x=radius*cos(i);
y=radius*sin(i);
Serial.print(x);
Serial.print(",");
Serial.println(y);
i=i+i;
x=radius*cos(i);
y=radius*sin(i);
//Serial.print(x);
//Serial.print(",");
//Serial.println(y);
There’s a variant of Bresenham’s algorithm for circles.
Alternatively, think Pythagoras, not polar.
Is a justifiably-hated phrase around these parts.
Hi thanks TheMemberFormerlyKnownAsAWOL
I am not very good at maths I was hoping for an easy formula I looked up Bresenham's algorithm for circles
but got lost after the first paragraph.
Thanks
Bob
i tested it, the formula works great, the way you are reading from Serial isn't right
Hi KASSIMSAMJI
can you explain what I am doing wrong.
Thanks
Bob
Redpiperbob:
Hi KASSIMSAMJI
Thanks
Bob
see this tutorial here
you will be able to properly read data from Serial
Use “360.0” to make sure that i comes out as a fraction.
x=radius*cos(i);
y=radius*sin(i);
i=i+i;
You are doubling i each time instead of incrementing by j. (and i should probably start at 0)
Redpiperbob:
Bob
while the code for using polar coordinates is OK, wuold it not be simpler and less 'hard' on the arduino to just use the cartesian equation of a circle:
x^2 + y^2 = r^2 for a circle starting at 0,0
the code I reckon would simpler as well; basically its would be for each 'step' in 'x' in the range -r to r calculate 'y', then move to that point.
step being the 'x' distance between each hole.
Hi Sherzaad
could you maybe show me some code to do want I want please
Thanks
Bob
Hi Westfw
thanks for that
I alered the code but i am getting strange resualts.for instance if I have a circle of 30 mm radius and want 4 points around the circumfeence the x,y coordinates should be 0,30/-30,0/0,-30/30,0
But I get 0.01,30.00/-26.82,-13.43/24.03,-17.96/5.29,29.53/
the code in red is completely wrong it should read 0,-30
float r=0;
float radius=0;
float h=0;
float holes=0;
float j=0;
float i=0;
float x=0;
float y=0;
j=360.0/holes;//convert holes to degrees per positon
i=j*3.141/180;//convert to degrees per positon radians
  x=radius*cos(i);
  y=radius*sin(i);
  Serial.print(x);
  Serial.print(",");
  Serial.print(y);
  i=i+j;
  Serial.print("/");
sherzaad:
Perhaps the equation is "simpler", but it makes it really hard to locate the points equally-spaced around the circle's circumference.
You’re close. Try:
  float theta, increment, x, y;
  float radius = 30.0;
  uint16_t numPoints = 4;
  theta = 0.0;
  increment = 2 * PI / numPoints;
  for (uint16_t i = 0; i < numPoints; i++) {
    x = radius * cos(theta);
    y = radius * sin(theta);
    Serial.print("X = ");
    Serial.print(x, 4);
    Serial.print(", Y = ");
    Serial.println(y, 4);
    theta += increment;
X = 30.0000, Y = 0.0000
X = -0.0000, Y = 30.0000
X = -30.0000, Y = -0.0000
X = 0.0000, Y = -30.0000
Hi Gfvalvo
Thats it works perfect sir you are a genuis
Thank you
Bob
gfvalvo:
Perhaps the equation is “simpler”, but it makes it really hard to locate the points equally-spaced around the circle’s circumference.
Your absolutely right! found that out the hard way… well it was good experimentation for me! :slight_smile:
anyway, here’s my code to read in from serial monitor the circle radius and number of equally spaced holes to be made and output the xy positions on the holes.
const byte numChars = 16;
const float pi = 3.141592;
char receivedChars[numChars];
float radius = 0;
uint16_t holes = 0;
  Serial.println(F("Enter Circle Radius and Number of Holes <radius,holes>:"));
  if (ReceiveUserInput()) {
    float i = (2 * pi) / holes; //convert holes to radians per positon
    //first point
    float x = radius;
    float y = 0;
    Serial.print(x);
    Serial.print(F(","));
    Serial.println(y);
    //remaining points
    for (uint16_t j = 1; j < holes; j++) {
      x = radius * cos(i * j);
      y = radius * sin(i * j);
      Serial.print(x);
      Serial.println(y);
boolean ReceiveUserInput() {
  static boolean recvInProgress = false;
  static byte ndx = 0;
  char startMarker = '<';
  char delimiter = ',';
  char endMarker = '>';
  char rc;
  boolean DataReady = false;
  while (Serial.available() > 0) {
    rc = Serial.read();
    if (recvInProgress == true) {
      if (rc != endMarker) {
        if (rc != delimiter) {
          receivedChars[ndx] = rc;
          ndx++;
        else {
          receivedChars[ndx] = '\0'; // terminate the string
          radius = atof(receivedChars);
          ndx = 0;
        if (ndx >= numChars) {
          return false;
      else {
        holes = atoi(receivedChars);
        ndx = 0;
        DataReady = true;
    else if (rc == startMarker) {
      recvInProgress = true;
      DataReady = false;
  return DataReady;
  for (int k = 0; k <= holes - 1; k++)
    float angle = i * k;
    x = radius * cos(angle);
    y = radius * sin(angle);
    Serial.print(x);
    Serial.print(",");
    Serial.println(y);
Pretty unusual and somewhat convoluted.:
johnwasser:
Conventional practice is:
  for (int k = 0; k < holes; k++)
