Found 4 num characters data from txt
Hello people! I hope you can help me with my problem, I want to type numers with a keypad and see if there's a match in a passwords list in a txt saved in a SD card, my problem now is that I dont know how to read 4 consecutive numbers from the txt, I search but I only found the way to detect a change line but how can I read and store in a variable every 4 consecutive numers?
this is the code what I have for see change lines
File myFile = SD.open("pass.txt",FILE_READ);
if (myFile)
while (myFile.available())
if( myFile.peek() == '\n' )
Serial.println(" Found line break");
Serial.write( myFile.read() );
this is the content of my txt
#ID PASSWORD
1 0414
2 9456
3 3028
4 3291
5 0583
Read them one at a time.
   if(myFile.available() > 3) // As if you'd be reading someone else's file
      char one = myFile.read();
      char two = myFile.read();
      char three = myFile.read();
      char four = myFile.read();
      // Do something with the 4 characters...
Of course, an array could prove useful...
Thanks for your help PaulS, I’m working with your code because it recognize all characters, this is what I have for now hehe
if(myFile.available()<=1)
int i = 0;
for (i==0; i==9; i++);
if (i == myFile.read())
numeracion[pass] = myFile.read();
if (numeracion[pass] == 4)
Serial.println(“password encontrado es:”) ;
for (int prin=0; prin=3; prin++)
Serial.println(numeracion[pass]);
it doesn’t work, im on it
Reading stuff from the file only if there is one character or less in to be read doesn’t make a lot of sense.
            int i = 0;
The first clause is an assignment operation, NOT a comparison operation.
The second clause is a while condition. Starting with i equal to 0, while i equals 9, is not going to iterate many times.
Testing one character read from the file, and using the next one unconditionally does not make sense.
At least, could you help me reading character by character? or where can I find information about it? I'll thank you so much because I dont find information about it.
Sure. I did that in reply #1. I don’t understand how you translated that straightforward code into the mess you made.
If you know that the cursor in the file is at the start of the 4 characters you want to read:
   int number = -1;
   if(myFile.available() >= 4)
      for(byte i=0; i<4; i++)
         numeracion[i] = myFile.read();
      numeracion[4] = '\0';
      number = atoi(numeracion);
   Serial.print("number = ");
   Serial.println(number);
