Found objects and diy switches
Arduino: 1.8.19 (Mac OS X), Board: "Arduino Uno"
code_hacking_-Found_Objects_and_DIY_Switches_Emily_Honderich:2:1: error: expected unqualified-id before numeric constant
1 /*
code_hacking
-Found_Objects_and_DIY_Switches_Emily_Honderich:33:1: error: expected unqualified-id before numeric constant
32 int ledPins[] = {
code_hacking
-Found_Objects_and_DIY_Switches_Emily_Honderich:37:1: error: expected unqualified-id before numeric constant
36 int pinCount = 6; // the number of pins (i.e. the length of the array)
code_hacking
-Found_Objects_and_DIY_Switches_Emily_Honderich:38:1: error: expected unqualified-id before numeric constant
38
code_hacking
-Found_Objects_and_DIY_Switches_Emily_Honderich:44:29: error: 'thisPin' does not name a type
44 for (int thisPin = 0; thisPin < pinCount; thisPin++) {
code_hacking
-Found_Objects_and_DIY_Switches_Emily_Honderich:44:49: error: 'thisPin' does not name a type
code_hacking
-Found_Objects_and_DIY_Switches_Emily_Honderich:49:1: error: expected unqualified-id before numeric constant
49
code_hacking
-Found_Objects_and_DIY_Switches_Emily_Honderich:55:29: error: 'thisPin' does not name a type
55 for (int thisPin = 0; thisPin < pinCount; thisPin++) {
code_hacking
-Found_Objects_and_DIY_Switches_Emily_Honderich:55:49: error: 'thisPin' does not name a type
code_hacking
-Found_Objects_and_DIY_Switches_Emily_Honderich:68:1: error: expected unqualified-id before numeric constant
68 Array
code_hacking
-Found_Objects_and_DIY_Switches_Emily_Honderich:71:40: error: 'thisPin' does not name a type
71 for (int thisPin = pinCount - 1; thisPin >= 0; thisPin--) {
code_hacking
-_Found_Objects_and_DIY_Switches_Emily_Honderich:71:54: error: 'thisPin' does not name a type
exit status 1
option enabled in File -> Preferences.
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
Looks like you have copied and pasted code which has line numbers. Delete them.
