Found SD card but not file
Hi all,
Im trying to do a udemy class on creating a webpage with the arduino uno and ethernet sheild. Ive followed the instructions and cannot get my arduino to see the "index.htm" file. has anyone one had this problem before? How do i fix it? below is the code.
#include <SD.h>                                               // The SD library allows for reading from and writing to SD cards
#include <SPI.h>
#include <Ethernet.h>
#define REQ_BUF_SZ   50                                       // size of buffer used to capture HTTP requests
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };          // MAC address from Ethernet shield sticker under board (if present)
IPAddress ip(192, 168, 0, 106);                              // Enter your IP address found using IP address finder in a previous lecture
EthernetServer miniServer(80);
File SdCardFile;                                              // the web page file on the SD card
boolean SWITCH_state[4] = {0};                                // stores the states of the Switches
char HTTP_request[REQ_BUF_SZ] = {0};                          // buffered HTTP request stored as null terminated string
char request_index = 0;                                       // index into HTTP_req buffer
    // For the Ethernet shield to work properly, you must make pin 10 an output and high before initializing the SD card as
    // both the SD card and Ethernet controller cannot use the SPI bus simultaneously.
    pinMode(10, OUTPUT);
    digitalWrite(10, HIGH);
    pinMode(5, OUTPUT);     // Switch #1
    pinMode(6, OUTPUT);     // Switch #2
    pinMode(7, OUTPUT);     // Switch #3
    pinMode(8, OUTPUT);     // Switch #4
    // Initialize Switches
    digitalWrite(5, HIGH);
    digitalWrite(6, HIGH);
    digitalWrite(7, HIGH);
    digitalWrite(8, HIGH);
    Serial.begin(9600);                                       // for debugging only
    Ethernet.begin(mac, ip);                                  // initialize Ethernet device
    miniServer.begin();
    // initialize SD card
    Serial.println("Initializing SD card...");
    if (!SD.begin(4)) {
        Serial.println("ERROR - Bad or missing SD card");
        return;
    Serial.println("SUCCESS - SD card found");
    if (!SD.exists("fts"))  {                           // check the file system to see if their is a file named index.htm
        Serial.println("ERROR - Can't find fts file!");
        return;
    Serial.println("SUCCESS - Found fts file.");
    // listen for incoming clients
    EthernetClient client = miniServer.available();
    if (client) {
        // an http request ends with a blank line
        boolean currentLineIsBlank = true;
        while (client.connected()) {
            if (client.available()) {                         // Returns the number of bytes available for reading
                char c = client.read();                       // read 1 byte (character) from client
                if (request_index < (REQ_BUF_SZ - 1)) {       // buffer first part of HTTP request in HTTP_req array
                    HTTP_request[request_index] = c;          // save HTTP request character
                    request_index++;
                // if you've gotten to the end of the line (received a newline
                // character) and the line is blank, the http request has ended,
                // so you can send a reply
                if (c == '\n' && currentLineIsBlank) {
                    // send a standard http response header
                    // remainder of header follows below, depending on if
                    // web page or XML page is requested
                    // Ajax request - send XML file
                    if (StrContains(HTTP_request, "ajax_inputs")) {
                        // send rest of HTTP header
                        client.println("Content-Type: text/xml");
                        client.println("Connection: keep-alive");
                        client.println();
                        // send XML file containing input states
                        SetSWITCHES();
                        XML_response(client);
                    else  {
                        // web page request
                        client.println("Content-Type: text/html");
                        client.println("Connection: close");
                        client.println();
                        // send web page
                        SdCardFile = SD.open("index.htm");        // open web page file
                        if (SdCardFile) {
                          while(SdCardFile.available()) {
                            client.write(SdCardFile.read());      // send web page to client
                        SdCardFile.close();
                    // display received HTTP request on serial port
                    Serial.println(HTTP_request);
                    // reset buffer index and all buffer elements to 0
                    request_index = 0;
                    StrClear(HTTP_request, REQ_BUF_SZ);
                if (c == '\n') {
                    // you're starting a new line
                else if (c != '\r') {
                    // you've gotten a character on the current line
                    currentLineIsBlank = false;
            } // end of client.available
        } // end of client.connected
        delay(1); // give the web browser time to receive the data
        client.stop(); // close the connection
char StrContains(char *str, char *sfind)
// searches for the string sfind in the string str, returns 1 if string found or returns 0 if string not found.
    char found = 0;
    char index = 0;
    char len;
    len = strlen(str);
    if (strlen(sfind) > len) {
        return 0;
    while (index < len) {
        if (str[index] == sfind[found]) {
            found++;
            if (strlen(sfind) == found) {
                return 1;
        else {
            found = 0;
        index++;
    return 0;
void XML_response(EthernetClient cl)
    // Sending Gauge Values to webclient
    cl.print("<?xml version = \"1.0\" ?>");
    cl.print("<inputs>");
    // Sending SWITCH states to dashboard
    // SWITCH #1
    cl.print("<SW>");
    if (SWITCH_state[0]) {
        cl.print("checked");
    else {
        cl.print("unchecked");
    cl.println("</SW>");
    // SWITCH #2
    cl.print("<SW>");
    if (SWITCH_state[1]) {
    else {
    // SWITCH #3
    cl.print("<SW>");
    if (SWITCH_state[2]) {
    else {
    // SWITCH #4
    cl.print("<SW>");
    if (SWITCH_state[3]) {
    else {
    cl.print("</inputs>");
void SetSWITCHES(void)
// checks if received HTTP request is switching any of our switches
    // SWITCH #1
    if (StrContains(HTTP_request, "SW1=1")) {
        SWITCH_state[0] = 1;  // save SWITCH state
        digitalWrite(5, LOW);
    else if (StrContains(HTTP_request, "SW1=0")) {
        SWITCH_state[0] = 0;  // save SWITCH state
    // SWITCH #2
    if (StrContains(HTTP_request, "SW2=1")) {
        SWITCH_state[1] = 1;  // save SWITCH state
        digitalWrite(6, LOW);
    else if (StrContains(HTTP_request, "SW2=0")) {
        SWITCH_state[1] = 0;  // save SWITCH state
    // SWITCH #3 (
    if (StrContains(HTTP_request, "SW3=1")) {
        SWITCH_state[2] = 1;  // save SWITCH state
        digitalWrite(7, LOW);
    else if (StrContains(HTTP_request, "SW3=0")) {
        SWITCH_state[2] = 0;  // save SWITCH state
    // SWITCH #4
    if (StrContains(HTTP_request, "SW4=1")) {
        SWITCH_state[3] = 1;  // save SWITCH state
        digitalWrite(8, LOW);
    else if (StrContains(HTTP_request, "SW4=0")) {
        SWITCH_state[3] = 0;  // save SWITCH state
void StrClear(char *str, char length)
// sets every element of str to 0 (clears array)
    for (int i = 0; i < length; i++) {
        str[i] = 0;
just out of interest have you tried naming it index.html instead of index.htm?
How do you know?
FYI, the standard strstr() function can replace your StrContains().
I named the file index and the file is a html type so it was getting confused.
Serial print said file was not found. But I figured it out.
Yeah unfortunately not my code. But thank you.
