Not new to Arduino but this has me stumped !
The last if statement (if (SCALE_Z_ENABLED == 1) { in the loop() will not execute.
When I move the code to be the 1st, 2nd or 3rd If statement then it executes, but then the 4th one will not.
if (SCALE_Z_ENABLED == 1) is true so I cannot understand what is going on, its a relativly simple loop().
Sorry for posting the whole code but thought it would make it easier to understand.
[code]
Created: 17-06-2023
Author: Mike Welling
Revisions:
19-06-2023 Added detection of valid axis Data to AutoEnable individual axis
# Chinese Capacitive Scales Protocol:
# 2540 Count per Inch, 24 bit word (6 x 4bit), last nibble only used for sign (bit 21)
# X, Y, Z & W Axis:
# X is Left-Right movement of Lathe Tool X
# Y is Cross-Slide movement Y
# Z is Compound movement Xc
# W is TailStock movement Ts
# The Serial Protocol used by TouchDRO uses plain ASCII (char).
# The format is Axis + Absolute position in Counts Per Inch(float) and ended with a terminating character ";"
# Example: X1234567;Y2345678;Z3456789;
# various bits of code pinched from other sources - thanks to all of you
// Scale Enabled function set automaticaly on detection of valid Data pulses
int SCALE_X_ENABLED = 0 ; // all axis set to Disabled initially
int SCALE_Y_ENABLED = 0 ;
int SCALE_Z_ENABLED = 0 ;
int SCALE_W_ENABLED = 0 ;
#define SCALE_X_CLK_PIN 2 // X Axis Clock pin
#define SCALE_X_DATA_PIN 3 // X Axis Data pin
#define SCALE_Y_CLK_PIN 5 // Y Axis Clock pin
#define SCALE_Y_DATA_PIN 4 // Y Axis Data pin
#define SCALE_Z_CLK_PIN 6 // Z Axis Clock pin
#define SCALE_Z_DATA_PIN 7 // Z Axis Data pin
#define SCALE_W_CLK_PIN 8 // W Axis Clock pin
#define SCALE_W_DATA_PIN 9 // W Axis Data pin
#define ENABLEDX_LED 10 // LED indicating X Axis Enabled, scale plugged in & outputting clock pulses
#define ENABLEDY_LED 11 // LED indicating Y Axis Enabled, scale plugged in & outputting clock pulses
#define ENABLEDZ_LED 12 // LED indicating Z Axis Enabled, scale plugged in & outputting clock pulses
#define ENABLEDW_LED 13 // LED indicating W Axis Enabled, scale plugged in & outputting clock pulses
float X_Readout = 40.0; // test data only, overwritten later in code
float Y_Readout = 30.0;
float Z_Readout = 20.0;
float W_Readout = 10.0;
int bit_arrayX[24]; // For storing the X Axis data - bit_array[1] = data bit 1 (LSB), bit_array[23] = data bit 24 (MSB)
int bit_arrayY[24]; // For storing the Y Axis data - bit_array[1] = data bit 1 (LSB), bit_array[23] = data bit 24 (MSB)
int bit_arrayZ[24]; // For storing the Z Axis data - bit_array[1] = data bit 1 (LSB), bit_array[23] = data bit 24 (MSB)
int bit_arrayW[24]; // For storing the W Axis data - bit_array[1] = data bit 1 (LSB), bit_array[23] = data bit 24 (MSB)
unsigned long time_now; // For storing the time when the clock signal is changed from HIGH to LOW (falling edge trigger of data output).
Serial.begin(115200); // set 115200 baud rate to HC-06 BT module
pinMode(SCALE_X_CLK_PIN, INPUT);
pinMode(SCALE_X_DATA_PIN, INPUT);
pinMode(SCALE_Y_CLK_PIN, INPUT);
pinMode(SCALE_Y_DATA_PIN, INPUT);
pinMode(SCALE_Z_CLK_PIN, INPUT);
pinMode(SCALE_Z_DATA_PIN, INPUT);
pinMode(SCALE_W_CLK_PIN, INPUT);
pinMode(SCALE_W_DATA_PIN, INPUT);
pinMode(ENABLEDX_LED, OUTPUT);
pinMode(ENABLEDY_LED, OUTPUT);
pinMode(ENABLEDZ_LED, OUTPUT);
pinMode(ENABLEDW_LED, OUTPUT);
digitalWrite(ENABLEDX_LED, LOW); // Turn OFF ALL Enabled LED Indications
digitalWrite(ENABLEDY_LED, LOW);
digitalWrite(ENABLEDZ_LED, LOW);
digitalWrite(ENABLEDW_LED, LOW);
// Auto Detect which Axis are plugged in & have a valid Clock signal, to enable each Axis individually, turn on Axis LED when Enabled.
long pulseDurationX = pulseIn(SCALE_X_CLK_PIN, LOW);
long pulseDurationY = pulseIn(SCALE_Y_CLK_PIN, LOW);
long pulseDurationZ = pulseIn(SCALE_Z_CLK_PIN, LOW);
long pulseDurationW = pulseIn(SCALE_W_CLK_PIN, LOW);
if (pulseDurationX > 50)SCALE_X_ENABLED = 1, digitalWrite(ENABLEDX_LED, HIGH);
if (pulseDurationY > 50)SCALE_Y_ENABLED = 1, digitalWrite(ENABLEDY_LED, HIGH);
if (pulseDurationZ > 50)SCALE_Z_ENABLED = 1, digitalWrite(ENABLEDZ_LED, HIGH);
if (pulseDurationW > 50)SCALE_W_ENABLED = 1, digitalWrite(ENABLEDW_LED, HIGH);
// Test data whilst establishing Auto Detect of Axis Enable
Serial.print("X Pulse Duration: ");
Serial.println(pulseDurationX);
Serial.print("Y Pulse Duration: ");
Serial.println(pulseDurationY);
Serial.print("Z Pulse Duration: ");
Serial.println(pulseDurationZ);
Serial.print("W Pulse Duration: ");
Serial.println(pulseDurationW);
Serial.println("Scales Enabled: ");
Serial.print("X = ");
Serial.println(SCALE_X_ENABLED);
Serial.print("Y = ");
Serial.println(SCALE_Y_ENABLED);
Serial.print("Z = ");
Serial.println(SCALE_Z_ENABLED);
Serial.print("W = ");
Serial.println(SCALE_W_ENABLED);
if (SCALE_X_ENABLED == 1) {
while (digitalRead(SCALE_X_CLK_PIN) == LOW) {} // If clock is LOW wait until it turns to HIGH
time_now = micros(); // When input goes HIGH set time_now
while (digitalRead(SCALE_X_CLK_PIN) == HIGH) {} // Wait for the end of the HIGH pulse
if ((micros() - time_now) > 1000) { // If the HIGH pulse was longer than 1000 micros we are at the start of a new bit sequence
decodeX(); // decode the X Axis bit sequence
if (SCALE_Y_ENABLED == 1) {
while (digitalRead(SCALE_Y_CLK_PIN) == LOW) {} // If clock is LOW wait until it turns to HIGH
while (digitalRead(SCALE_Y_CLK_PIN) == HIGH) {} // Wait for the end of the HIGH pulse
decodeY(); // decode the Y Axis bit sequence
if (SCALE_W_ENABLED == 1) {
while (digitalRead(SCALE_W_CLK_PIN) == LOW) {} // If clock is LOW wait until it turns to HIGH
while (digitalRead(SCALE_W_CLK_PIN) == HIGH) {} // Wait for the end of the HIGH pulse
decodeW(); // decode the W Axis bit sequence
while (digitalRead(SCALE_Z_CLK_PIN) == LOW) {} // If clock is LOW wait until it turns to HIGH
while (digitalRead(SCALE_Z_CLK_PIN) == HIGH) {} // Wait for the end of the HIGH pulse
decodeZ(); // decode the Z Axis bit sequence
Serial.println("End of Loop"); // Test only !!
delay(5);
void decodeX() {
// reset variables
int sign = 1;
int i = 0;
float result = 0.0;
bit_arrayX[i] = digitalRead(SCALE_X_DATA_PIN); // Store the 1st bit (start bit) which is always 1.
while (digitalRead(SCALE_X_CLK_PIN) == HIGH) {};
for (i = 1; i <= 24; i++) {
while (digitalRead(SCALE_X_CLK_PIN) == LOW) {} // Wait until clock returns to HIGH
while (digitalRead(SCALE_X_CLK_PIN) == HIGH) {} // Wait until clock returns to LOW
for (i = 1; i <= 20; i++) { // Turning the result in the bit array from binary to decimal, i=1 skip LSB
result = result + (pow(2, i - 1) * bit_arrayX[i]);
if (bit_arrayX[21] == 0) sign = -1; // Bit 21 is the sign bit. 0 = -ve, 1 = +ve - *** CHANGE THIS TO SUIT ORIENTATION OF SCALE ON LATHE ***
X_Readout = (result * sign) / 100.00;
Serial.println("X" + String(X_Readout) + ";"); // Output X Axis data to TouchDRO
Serial.println("X Axis Data Stream");
for (i = 0; i <= 24; i++) { // Show the content of the bit array. This is for verification only.
Serial.print(bit_arrayX[i]);
Serial.print(" ");
Serial.print("X Axis Distance = ");
Serial.print(X_Readout, 2); // Print result with 2 decimals
Serial.print(" mm, ");
Serial.print((X_Readout / 25.4), 3); // display result in Inches to 3 decimal places
Serial.println(" \"");
void decodeY() {
// reset variables
int sign = 1;
int i = 0;
float result = 0.0;
bit_arrayY[i] = digitalRead(SCALE_Y_DATA_PIN); // Store the 1st bit (start bit) which is always 1.
while (digitalRead(SCALE_Y_CLK_PIN) == HIGH) {};
while (digitalRead(SCALE_Y_CLK_PIN) == LOW) {} // Wait until clock returns to HIGH
while (digitalRead(SCALE_Y_CLK_PIN) == HIGH) {} // Wait until clock returns to LOW
result = result + (pow(2, i - 1) * bit_arrayY[i]);
if (bit_arrayY[21] == 0) sign = -1; // Bit 21 is the sign bit. 0 = -ve, 1 = +ve - *** CHANGE THIS TO SUIT ORIENTATION OF SCALE ON LATHE ***
Y_Readout = (result * sign) / 100.00;
Serial.println("Y" + String(Y_Readout) + ";"); // Output Y Axis data to TouchDRO
Serial.println("Y Axis Data Stream");
Serial.print(bit_arrayY[i]);
Serial.print(" ");
Serial.print("Y Axis Distance = ");
Serial.print(Y_Readout, 2); // Print result with 2 decimals
Serial.print((Y_Readout / 25.4), 3); // display result in Inches to 3 decimal places
void decodeZ() {
// reset variables
int sign = 1;
int i = 0;
float result = 0.0;
bit_arrayZ[i] = digitalRead(SCALE_Z_DATA_PIN); // Store the 1st bit (start bit) which is always 1.
while (digitalRead(SCALE_Z_CLK_PIN) == HIGH) {};
while (digitalRead(SCALE_Z_CLK_PIN) == LOW) {} // Wait until clock returns to HIGH
while (digitalRead(SCALE_Z_CLK_PIN) == HIGH) {} // Wait until clock returns to LOW
result = result + (pow(2, i - 1) * bit_arrayZ[i]);
if (bit_arrayZ[21] == 0) sign = -1; // Bit 21 is the sign bit. 0 = -ve, 1 = +ve - *** CHANGE THIS TO SUIT ORIENTATION OF SCALE ON LATHE ***
Z_Readout = (result * sign) / 100.00;
Serial.println("Z" + String(Z_Readout) + ";"); // Output Z Axis data to TouchDRO
Serial.println("Z Axis Data Stream");
Serial.print(bit_arrayZ[i]);
Serial.print(" ");
Serial.print("Z Axis Distance = ");
Serial.print(Z_Readout, 2); // Print result with 2 decimals
Serial.print((Z_Readout / 25.4), 3); // display result in Inches to 3 decimal places
void decodeW() {
// reset variables
int sign = 1;
int i = 0;
float result = 0.0;
bit_arrayW[i] = digitalRead(SCALE_W_DATA_PIN); // Store the 1st bit (start bit) which is always 1.
while (digitalRead(SCALE_W_CLK_PIN) == HIGH) {};
while (digitalRead(SCALE_W_CLK_PIN) == LOW) {} // Wait until clock returns to HIGH
while (digitalRead(SCALE_W_CLK_PIN) == HIGH) {} // Wait until clock returns to LOW
result = result + (pow(2, i - 1) * bit_arrayW[i]);
if (bit_arrayW[21] == 0) sign = -1; // Bit 21 is the sign bit. 0 = -ve, 1 = +ve - *** CHANGE THIS TO SUIT ORIENTATION OF SCALE ON LATHE ***
W_Readout = (result * sign) / 100.00;
Serial.println("W" + String(W_Readout) + ";"); // Output W Axis data to TouchDRO
Serial.println("W Axis Data Stream");
Serial.print(bit_arrayW[i]);
Serial.print(" ");
Serial.print("W Axis Distance = ");
Serial.print(W_Readout, 2); // Print result with 2 decimals
Serial.print((W_Readout / 25.4), 3); // display result in Inches to 3 decimal places
[/code]
