Wire up four LED's to pins 0-4 of the Fubarino. does nothing until a button is pressed. When the button is pressed, successively light up one LED until all four are lit with a one second delay between each light. Then wait one more second and shut off all LED's. If the button is pressed again it will repeat the behavior described above.
current error expected unqualified id bfore { token
Ive tried many if else statements , if else if all to differnt fails.
uint16_t PIN_OUT[4] = {0,1,2,3}; //
uint16_t PIN_IN = 4; //
pinMode(PIN_OUT[0], OUTPUT);
pinMode(PIN_OUT[1], OUTPUT);
pinMode(PIN_OUT[2], OUTPUT);
pinMode(PIN_OUT[3], OUTPUT);
pinMode(PIN_IN, INPUT);
digitalWrite(PIN_OUT[0], !digitalRead(PIN_OUT[0])); // toggle the LED
if( digitalRead(PIN_IN) == LOW ) { // Made decision
digitalWrite(PIN_IN, LOW);
else {
delay(4000); // false condition
digitalWrite(PIN_OUT[1], !digitalRead(PIN_OUT[1])); // toggle the LED
if( digitalRead(PIN_OUT[0]) == HIGH ) { // Made decision
delay(3000); // false condition
digitalWrite(PIN_OUT[2], !digitalRead(PIN_OUT[2])); // toggle the LED
if( digitalRead(PIN_OUT[1]) == HIGH ) { // Made decision
delay(2000); // false condition
digitalWrite(PIN_OUT[3], !digitalRead(PIN_OUT[3])); // toggle the LED
if( digitalRead(PIN_OUT[2]) == HIGH ) { // Made decision
delay(1000); // false condition
A very helpful troubleshooting tool is the Auto Format feature (Tools > Auto Format in the Arduino IDE or Ctrl + B in the Arduino Web Editor). If you do an Auto Format and then compare the resulting indentation to your intended program structure, it will quickly point you to where there is a missing or extra brace. It will also be a polite thing to auto format your code before posting it on the Arduino Forum. The code you posted looks absolutely horrible and is difficult for us to read.
Another useful feature of the Arduino IDE/Arduino Web Editor is that when you place the cursor next to one bracket, it puts a box around the matching bracket. In the Arduino IDE, if the cursor is next to the closing bracket and the opening bracket is off the screen then it will show the opening bracket line in a tool tip after a short delay.
4-LED Blink
If switch 1 is pressed, D1 will blink once.
If switch 2 is pressed, D2 will blink twice.
If switch 3 is pressed, D3 will blink 3x.
If switch 4 is pressed, D4 will blnk 4x.
