Four thermocouple & flow meter sensor compiling issue
this program code is for a particular part in my graduation project, where the flow meter sensor measure the rate of the fluid at the inlet pipe and at each node( 4 nodes) of crossing pipes (two or three pipes interfere with each other acting as Mixing Unit) a thermocouple is fitted to measure the temperature at each node (interfering point between pipes) and to display all of these data on the Serial monitor .
i've tried to write my own code but it didn't even compile, i am working with UNO board .
can anyone help me with the code please ?!
and if you may have any upgrade to the could ?!
  #include "max6675.h"
  //for the First thermocouple
    int tc1SO = 2;
    int tc1CS = 3;
    int tc1CLK =4;
    MAX6675 tc1 = ( 4 , 3 , 2); // for reading the output of first thermocouple
  //for the second thermocouple
     int tc2SO = 5;
     int tc2CS = 6;
     int tc2CLK = 7;
     MAX6675 tc2 = (7 , 6 , 5); // for reading output of second thermocouple
  //for the third thermocouple
     int tc3SO=8;
     int tc3CS=9;
     int tc3CLK=10;
     MAX6675 tc3 = (10 , 9 , 8); //for reading output of third thermocouple
  //for the fourth thermocouple
    int tc4SO=11;
    int tc4CS=12;
    int tc4CLK=13;
    MAX6675 tc4 = (13 , 12 , 11);
  //for the flow meter sensor
    int X;
    int Y;
    float TIME = 0;
    float FREQUENCY = 0;
    float WATER = 0;
    float TOTAL = 0;
    float LS = 0;
    const int input = A0;
       pinMode(input, INPUT);           //Sets the pin as an input
      X = pulseIn(input, HIGH);
      Y = pulseIn(input, LOW);
      TIME = X + Y;
      FREQUENCY = 1000000/TIME;
      WATER = FREQUENCY/7.5;
      LS = WATER/60;
      if(FREQUENCY >= 0)
          if(isinf(FREQUENCY))
           {Serial.print("Vol. = 0.0")
            Serial.print("Total:");
            Serial.print(TOTAL);
            Serial.print("  L");
          else {
            TOTAL = TOTAL + LS;
            Serial.print("   Vol.");
            Serial.print(WATER);
            Serial.print("  L/M");
            Serial.print("   Total: ");
            Serial.print("  L");
      //first thermoC
      Serial.print("   ThermoC 1: ");
      Serial.print(tc1.readCelsius());
      Serial.print("  C");
      //second thermoC
      Serial.print("   ThermoC 2: ");
      Serial.print(tc2.readCelsius());
      Serial.print("  C");
      //Third ThermoC
      Serial.print("   ThermoC 3:");
      Serial.print(tc3.readCelsius());
      Serial.print("  C");
      //Fourth ThermoC
      Serial.print("   ThermoC 4:");
      Serial.print(tc4.readCelsius());
      Serial.print("  c");
And the error message is
exit status 1
conversion from 'int' to non-scalar type 'MAX6675' requested
your are incorrectly instating the objects.
instead of MAX6675 tc2 = (7 , 6 , 5); it should be MAX6675 tc2(7 , 6 , 5); for example
this code now compiles:
  int tc1SO = 2;
  int tc1CS = 3;
  int tc1CLK = 4;
MAX6675 tc1(4 , 3 , 2); // for reading the output of first thermocouple
  int tc2SO = 5;
  int tc2CS = 6;
  int tc2CLK = 7;
MAX6675 tc2(7 , 6 , 5); // for reading output of second thermocouple
  int tc3SO = 8;
  int tc3CS = 9;
  int tc3CLK = 10;
MAX6675 tc3(10 , 9 , 8); //for reading output of third thermocouple
  int tc4SO = 11;
  int tc4CS = 12;
  int tc4CLK = 13;
MAX6675 tc4(13 , 12 , 11);
int X;
int Y;
float TIME = 0;
float WATER = 0;
float TOTAL = 0;
float LS = 0;
  TIME = X + Y;
  FREQUENCY = 1000000 / TIME;
  WATER = FREQUENCY / 7.5;
  LS = WATER / 60;
  if (FREQUENCY >= 0)
    if (isinf(FREQUENCY))
    { Serial.print("Vol. = 0.0");
      Serial.print("  L");
    else {
      TOTAL = TOTAL + LS;
      Serial.print("  L");
  //first thermoC
  Serial.print("  C");
  //second thermoC
  Serial.print("  C");
  //Third ThermoC
  Serial.print("  C");
  //Fourth ThermoC
  Serial.print("  c");
Why are you starting a new thread for the same question as this one?
