FPGA-based routing of signals by Vidor4000
is something I've been reading more about than posting. There is already a lot of information out there, but I am working on a project. I was unsure if the Vidor could help me out with this build. My idea is to check first before ordering and finding out that it won't work. The Vidor4000 has a SamD21 processor, which I'm quite familiar with since we use it extensively. It would be great if there was some sort of router to switch between 16 to 32x i2s ( Sound ) onto multiple outputs. Sort of like a router. And i2s only has a maximum clock speed of 2,5 / 3,5 Mhz. There is not much signal there. But since there were many in and many out, I thought maybe that would meet my needs.
Considering I2S uses 3 lines (clock, word select, serial data) there's barely enough pins on the Vidor4000 to connect just 7 such interfaces. You'd need to rethink the approach.
You need 3 pin for each slave port. As master you can use 2 + N pins for interface where N is number of output devices if all devices are in sync.
Other solution is to do custom carrier board with mini pci-e. that have about 27 IO:s
If you are using FPGA as I2S master then you can use same SCL and WS. then you can use shift registers to SD. So with 2x 75hc595 you can get 16 output devices with 5 IO. Remember shift register clock should be 16x SCL if using 2 shift register. 74hc595 can run around 56MHz in 25C 5V. With 3.3v it's little slower so you may need to use slower clock or use shift registers as parallel.
For inputs use 74HC165.
Edit:
I was thinking case where you have 16 stereo ADC and 16 Stereo DAC. This should be available with 2x 74HC595 + 2x 74HC165 (SCL + WS + SCLK + SDo + SDi + 2x Parallel load -> 7 IO from FPGA for 16 DAC and 16 ADC)
