FPS_G511C3 fingerprint sensor fails to run sketches properly
Hi guys,
Im using this sensor (GT-511C3) here
Along with this library
If I add the debug = true line to the sketches I get this:
FPS - Open
FPS - SEND: "55 AA 01 00 00 00 00 00 01 00 01 01"
but nothing else happens. Im using the code examples from the library itself. Im using a 985Ω resistor and a 1.46kΩ as a divider.
Connections are
Arduino---------FPS
5V -------------Vcc
GND -----------GND
4 ---------------Tx
5 ---0.985------Rx
------1.46kΩ-----GND
I have to open the serial monitor a few times after upload in order for any sketch to work. Below are the Blink and Enroll sketches and what they give once I get them to work after opening the SM about 3 or 5 times after upload.
Here is FPS_Blink.ino:
 FPS_Enroll.ino - Library example for controlling the GT-511C3 Finger Print Scanner (FPS)
 Created by Josh Hawley, July 23rd 2013
 Licensed for non-commercial use, must include this license message
 basically, Feel free to hack away at it, but just give me credit for my work =)
 TLDR; Wil Wheaton's Law
 This simple sketch turns the LED on and off similar to the Arduino blink sketch.
 It is used to show that communications are working.
#include "FPS_GT511C3.h"
#include "SoftwareSerial.h"
// Hardware setup - FPS connected to:
//  digital pin 4(arduino rx, fps tx)
//  digital pin 5(arduino tx - 560ohm resistor fps tx - 1000ohm resistor - ground)
// this brings the 5v tx line down to about 3.2v so we dont fry our fps
FPS_GT511C3 fps(4, 5);
  //Serial.println("hi");
  delay(100);
 fps.UseSerialDebug = true; // so you can see the messages in the serial debug screen
 fps.Open();
 // FPS Blink LED Test
 fps.SetLED(true); // turn on the LED inside the fps
 fps.SetLED(false);// turn off the LED inside the fps
When it works I get:
FPS - Open
FPS - RECV: "55 AA 01 00 00 00 00 00 30 00 30 01"
FPS - LED on
FPS - SEND: "55 AA 01 00 01 00 00 00 12 00 13 01"
FPS - LED off
FPS - SEND: "55 AA 01 00 00 00 00 00 12 00 12 01"
FPS - LED on
FPS - LED off
FPS - LED on
Here is the FPS_Enroll.ino:
 Serial.begin(9600); //set up Arduino's hardware serial UART
 delay(100);
 fps.Open();         //send serial command to initialize fps
 fps.SetLED(true);   //turn on LED so fps can see fingerprint
 Enroll();          //begin enrolling fingerprint
void Enroll()
 // Enroll test
 // find open enroll id
 int enrollid = 0;
 bool usedid = true;
 while (usedid == true)
 usedid = fps.CheckEnrolled(enrollid);
 if (usedid==true) enrollid++;
 fps.EnrollStart(enrollid);
 // enroll
 Serial.print("Press finger to Enroll #");
 Serial.println(enrollid);
 while(fps.IsPressFinger() == false) delay(100);
 bool bret = fps.CaptureFinger(true);
 int iret = 0;
 if (bret != false)
 Serial.println("Remove finger");
 fps.Enroll1();
 while(fps.IsPressFinger() == true) delay(100);
 Serial.println("Press same finger again");
 if (bret != false)
 fps.Enroll2();
 Serial.println("Press same finger yet again");
 if (bret != false)
 iret = fps.Enroll3();
 if (iret == 0)
 Serial.println("Enrolling Successful");
 Serial.print("Enrolling Failed with error code:");
 Serial.println(iret);
 else Serial.println("Failed to capture third finger");
 else Serial.println("Failed to capture second finger");
 else Serial.println("Failed to capture first finger");
 delay(100000);
When it works I get this:
FPS - Open
FPS - LED on
FPS - CheckEnrolled
FPS - SEND: "55 AA 01 00 00 00 00 00 21 00 21 01"
FPS - RECV: "55 AA 01 00 04 10 00 00 31 00 45 01"
FPS - EnrollStart
FPS - SEND: "55 AA 01 00 00 00 00 00 22 00 22 01"
Press finger to Enroll #0
FPS - IsPressFinger
FPS - SEND: "55 AA 01 00 01 00 00 00 26 00 27 01"
FPS - RECV: "55 AA 01 00 12 10 00 00 30 00 52 01"
FPS - IsPressFinger
FPS - IsPressFinger
FPS - CaptureFinger
FPS - SEND: "55 AA 01 00 01 00 00 00 60 00 61 01"
FPS - RECV: "55 AA 01 00 12 10 00 00 31 00 53 01"
And at this last CaptureFinger is when I pressed my finger to the reader.
I just replaced my 1/2k resistors for 10/20k resistors and it seems to work "better". With enroll I'm able to get to the enroll prompt in the serial monitor and I even got 2 finger reads and the 3rd one failed. Unfortunately it seems that once something fails, the code isn't really designed to handle that and restart, it just hangs. I'll keep trying but it seems to be a voltage issue. I'm guessing it's very sensitive and tiny variances in resistors and perhaps now power source (I'm using the 5v from the USB-pc powered Arduino) and perhaps even the movement of the sensor when pressed may be causing the voltage issue which causes the comm issue which hangs the code.
