FR Feux tricolore
Bonjour je suis novice en programmation et je dois programmer ces voyants mais je ne sais pas comment m'y prendre, avez vous des conseils?
Give more details about these LEDs .... Just by looking at them, I think they are not of 5V so you may need to use relay or transistor in order to control them automatically.
The problem is they arent led , its light like the light in car (dont know the word in english for "voyant" ),you right its 12V.
"voyant" apparently just translates as "light", perhaps "light fitting" though that is "luminaire". Perhaps "indicator"; they do not appear to include switches.
So the thing is - what sort of lamp are they? Presumably incandescent bulbs, not many alternatives if they are not LED. From where did you get them and how much do you know about what voltage and current are required?
It might actually be appropriate to replace the bulbs with LEDs. (Voltage usually marked on the bulb!)
Ops post;
Hello I'm new to programming and I have to program these lights but I do not know how to do it, do you have any advice?
If you unscrew the colour lenses you will get access to the lamps inside.
They should have a part number or volt/current spec printed on them.
Si vous dévissez les lentilles de couleur, vous aurez accès aux lampes à l'intérieur.
Ils devraient avoir un numéro de pièce ou une spécification de volt / courant imprimés sur eux.
Tom.... :slight_smile:
@killian2
TOPIC LOCKED as OP has an identical post in another language
Do NOT CROSS POST as it wastes peoples time and efforts to help you.
Please READ THIS before adding any further posts.
Bob.
TOPIC LOCKED car OP a un poste identique dans une autre langue
NE PAS CROSS POST car cela fait perdre du temps et des efforts aux gens pour vous aider.
Veuillez LIRE CECI avant d'ajouter d'autres publications.
