Entlich durch suchen habe ich den Code gefunden
beid auf Pitch gestellt und macht genau das was ich will und Experementier noch herum damit um es auch zu verstehen genial.
Danke nochmal.
(ServoX.write(ServoPitch)
(ServoY.write(ServoPitch)
// MPU6050 & Servo
// https://www.giuseppecaccavale.it/
// Giuseppe Caccavale
#include <SPI.h>
#include <Wire.h>
#include <Servo.h>
#define MPU 0x68 // I2C address of the MPU-6050
Servo ServoX, ServoY;
double AcX, AcY, AcZ;
int Pitch, Roll;
ServoX.attach(8);
ServoY.attach(9);
init_MPU(); // Inizializzazione MPU6050
FunctionsMPU(); // Acquisisco assi AcX, AcY, AcZ.
Roll = FunctionsPitchRoll(AcX, AcY, AcZ); //Calcolo angolo Roll
Pitch = FunctionsPitchRoll(AcY, AcX, AcZ); //Calcolo angolo Pitch
int ServoRoll = map(Roll, -90, 90, 0, 179);
int ServoPitch = map(Pitch, -90, 90, 179, 0);
ServoX.write(ServoPitch);
ServoY.write(ServoPitch);
Serial.print("Pitch: "); Serial.print(Pitch);
Serial.print("\t");
Serial.print("Roll: "); Serial.print(Roll);
Serial.print("\n");
void init_MPU() {
Wire.begin();
Wire.beginTransmission(MPU);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
//Funzione per il calcolo degli angoli Pitch e Roll
double FunctionsPitchRoll(double A, double B, double C) {
double DatoA, DatoB, Value;
DatoA = A;
DatoB = (B * B) + (C * C);
DatoB = sqrt(DatoB);
Value = atan2(DatoA, DatoB);
Value = Value * 180 / 3.14;
return (int)Value;
//Funzione per l'acquisizione degli assi X,Y,Z del MPU6050
void FunctionsMPU() {
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU, 6, true); // request a total of 14 registers
AcX = Wire.read() << 8 | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY = Wire.read() << 8 | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ = Wire.read() << 8 | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
