Frage zum SD Karte beschreiben?
Dann stelle ich hier auch mal eine Frage, zur SD-Karte. :.
Irgend wann will ich sie auch mal für die Waage benutzen. :slight_smile:
Bei dem angehängten Test-Sketch, werden Datalog.txt Files angelegt.
Nur warum bekommen die alle 01.01.2000 01:00 als Erstelldatum mit angehängt?
Gruß, Apus²
#include <SD.h>
// On the Ethernet Shield, CS is pin 4. Note that even if it's not
// used as the CS pin, the hardware CS pin (10 on most Arduino boards,
// 53 on the Mega) must be left as an output or the SD library
// functions will not work.
const int chipSelect = 10;
File dataFile;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(SS, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    while (1) ;
  Serial.println("card initialized.");
  // Open up the file we're going to log to!
  dataFile = SD.open("datalog.txt", FILE_WRITE);
  if (! dataFile) {
    Serial.println("error opening datalog.txt");
    // Wait forever since we cant write data
    while (1) ;
  // make a string for assembling the data to log:
  String dataString = "";
  // read three sensors and append to the string:
  for (int analogPin = 0; analogPin < 3; analogPin++) {
    int sensor = analogRead(analogPin);
    dataString += String(sensor);
    if (analogPin < 2) {
      dataString += ",";
  dataFile.println(dataString);
  // print to the serial port too:
  Serial.println(dataString);
  // The following line will 'save' the file to the SD card after every
  // line of data - this will use more power and slow down how much data
  // you can read but it's safer!
  // If you want to speed up the system, remove the call to flush() and it
  // will save the file only every 512 bytes - every time a sector on the
  // SD card is filled with data.
  dataFile.flush();
  // Take 1 measurement every 500 milliseconds
Apus_Apus:
Um ein anderes Datum als das Default-Datum zu erhalten, müßtest Du
a) eine solche SD-Library verwenden, die das Setzen eine Datei Zeitstempels erlaubt und
b) die entsprechenden Funktionen in Deinem Sketch aufrufen, die den Zeitstempel setzen
Soweit eine kurze Google-Suche ergab, kann es die SdFat-Library über eine Callback-Funktion realisieren.
Die einfachere Variante ist, den Dateien stattdessen Namen zu geben, die gleichzeitig Zeitstempel sind (und auf die Zeitstempel zu pfeifen).
Z.B. für eine Log-Datei vom 15.03. 2013 einfach den Dateinamen "20130315.txt" vergeben, wenn Du eine Logdatei pro Tag haben möchtest. Wenn man solche Dateinamen nach Namen sortiert, sind sie gleichzeitig auch nach Datum sortiert, was das spätere Auffinden eines Datums in einer Dateiliste stark erleichtert. Den genauen Zeitstempel mit Uhrzeit loggst Du dann in den Log-Zeilen mit.
