I am experimenting with FRAM and I can't find out how to write float variables. I am using fram.write32(addrLoc, myData.humid); to write the variable and using humid=fram.read32(readLoc);,
myData.humid is a floating point variable but when I read it back, the decimal values are gone.
I suspect that the comand fram.write32 is writing a uint32_t, or long integer variable and so the decimals are removed.
I've gone through the examples but I can't find the syntax to wright a float.
Does anybody know the correct syntax to write a float?
The full sketch is below.
#include <esp_now.h>
#include <WiFi.h>
#include <Wire.h>
//#include <LiquidCrystal_I2C.h>
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "FRAM.h"
FRAM fram;
#define I2C_SDA 33
#define I2C_SCL 32
//LiquidCrystal_I2C lcd(0x27, 20, 4);
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// Structure example to receive data
// Must match the sender structure
typedef struct struct_Data {
char unit[8];
char timeStamp[32];
float humid;
float temperature;
float pressure;
float battVolt;
} struct_Data;
// Create a struct_message called myData
struct_Data myData;
int counter;
int counter2;
float pressure_hold[16];
bool press=0;
const unsigned long startAddr=1000;
unsigned long addrLoc=startAddr;
unsigned long readLoc;
const uint8_t IndexLoc = 100;
bool output = 0;
// callback function that will be executed when data is received
void OnDataRecv(const esp_now_recv_info_t * mac, const uint8_t *incomingData, int len) {
memcpy(&myData, incomingData, sizeof(myData));
Serial.println();
Serial.println(myData.unit);
char str[8];
strcpy(str, myData.unit);
fram.write(addrLoc, (uint8_t *)str, 8);
addrLoc+=8;
Serial.println(myData.timeStamp);
char str2[32];
strcpy(str2, myData.timeStamp);
fram.write(addrLoc, (uint8_t *)str2, 32);
addrLoc+=32;
Serial.println(myData.humid);
addrLoc+=4;
Serial.println(myData.temperature);
fram.write32(addrLoc, myData.temperature);
addrLoc+=4;
Serial.println(myData.pressure);
fram.write32(addrLoc, myData.pressure);
addrLoc+=4;
Serial.println(myData.battVolt);
fram.write32(addrLoc, myData.battVolt);
addrLoc+=4;
fram.write32(IndexLoc, addrLoc);
Serial.print("addrLoc = ");
Serial.println(addrLoc);
Serial.print( "Number of records = ");
int x=(addrLoc-startAddr)/56;
Serial.println( x);
Serial.println(counter);
pressure_hold[counter]=myData.pressure;
/*if(press){
lcd.setCursor(7, 1);
float meanPressure = arrayAverage(pressure_hold, 12);
Serial.println(meanPressure);
if(myData.pressure>meanPressure)
lcd.print("+");
else{
lcd.print("-");
counter++;
if (counter>=15)
counter = 0;
press=1;
output = 1;
// Initialize Serial Monitor
Wire.begin(I2C_SDA, I2C_SCL);
//fram.begin(0x50);
fram.begin(0x7C);
if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
//fram.write32(IndexLoc, startAddr);///set initial index point
//while(1)
addrLoc=fram.read32(IndexLoc);
Serial.print("addrLoc =");
Serial.println( x);
display.clearDisplay();
//lcd.init(); // initialize the lcd
//lcd.backlight();
// Set device as a Wi-Fi Station
WiFi.mode(WIFI_STA);
// Init ESP-NOW
if (esp_now_init() != ESP_OK) {
Serial.println("Error initializing ESP-NOW");
return;
// Once ESPNow is successfully Init, we will register for recv CB to
// get recv packer info
esp_now_register_recv_cb(OnDataRecv);
display.setTextSize(2); // Draw 2X-scale text
display.setTextColor(SSD1306_WHITE);
display.display();
allOutput();
delay(5000);
display.setCursor(0, 0);
display.println(F("H "));
display.setTextSize(4);
display.println(myData.humid,1);
display.println("%");
display.display();
delay(5000);
display.println(F("T "));
display.println(myData.temperature,1);
display.println(" C");
display.display();
delay(5000);
display.println("V ");
display.println(myData.battVolt,2);
display.display();
delay(5000);
if(output){readFram();output=0;}
float arrayAverage(float variable[], int count)
float num = 0;
for (int i = 0; i <= count - 1; i++)
num = num + variable[i]; // Calculate sum of all array values
float average = float(num / count);
return average;
void allOutput(){
display.print(F("H "));
display.print(myData.humid,1);
display.print(F("T "));
display.print(myData.temperature,1);
display.print("P ");
display.println(myData.pressure,0);
display.print("V ");
display.print(myData.battVolt,2);
display.display();
void readFram()
readLoc=startAddr;
char str[8];
char str2[32];
float humid;
float temperature;
float pressure;
float battVolt;
Serial.println();
while(readLoc<=addrLoc){
fram.read(readLoc, (uint8_t *)str, 8);
Serial.print(str);Serial.print(" ");
readLoc+=8;
fram.read(readLoc, (uint8_t *)str2, 32);
Serial.print(str2);Serial.print(" ");
readLoc+=32;
//fram.readObject(readLoc, humid);
Serial.print(humid);Serial.print(" ");
readLoc+=4;
temperature=fram.read32(readLoc);
//fram.readObject(readLoc, temperature);
Serial.print(temperature);Serial.print(" ");
readLoc+=4;
pressure=fram.read32(readLoc);
//fram.readObject(readLoc, pressure);
Serial.print(pressure);Serial.print(" ");
readLoc+=4;
battVolt=fram.read32(readLoc);
//fram.readObject(readLoc, battVolt);
Serial.println(battVolt);Serial.print(" ");
readLoc+=4;
int x=(readLoc-startAddr)/56;
Serial.println( x);
