free oled display for someone who can help me
Hi everyone I'm new here, I got gifted about 30 kyocera f and fc-51852. Really cool oled's with different bi-colored displays some are blue or yellow or black on white or white on black. I can get them working with their controller board via serial and a pc. I've recently been integrating different displays with my arduino collection. I built an awesome sensor box with temp sensors and pressure sensors sending all that data over serial, ethernet and to a lcd display. I'd really like to get the oled's working they seem so much more capable. so I'm attaching a pdf of the schematics, important points seem to be u2 which is an atmega 16, j4 which apparently is tx, rx. when jumpered those tx and rx connections are forwarded to an rs-232 or you can connect directly to the tx rx pins without jumpers. there's also the j2 standard ICSP. At the moment I'm trying to use the controller board but I only have one controller board, J1 shows the pin out for the display, ideally I would be able to connect these display directly to an arduino without the controller board. Anyone who might be able to help let me know I have the schematics which I'm attaching I also have the manual and data sheets.
  1. How can I connect to this controller board using Arduino DUE (I must be missing something simple, I can light it up and get it to blink with scan lines.
  2. how can I connect directly to these LCD's using the UNO
if someone can help me find the right pin's for the DUE and UNO I'll mail you a free OLED (Continental U.S. Only) of this type, very cool OLED's
TC553852Schematic.pdf (131 KB)
TC553852UM.pdf (864 KB)
Guide book.pdf (164 KB)
to connect to the controller, remove jumpers from J4, then Use J4 as a header to connect TXD, RXD, and GND from external arduino,or other device. pretty much, all of this is in the manual...
as for connecting the display directly to an arduino, not possible, you need a "carrier" board. basically, the display needs some supporting hardware, like decoupling capacitors, reference resistor etc.. these discreet components are essential...
Your best bet, is to replicate, or clone the original board, removing non-essential features, and adding your desired features..
