Initially I had trouble getting uploading to work on the command line in linux, but eventually got that all sorted out. Now I am getting the following error:
robind@Vlad ~/robotank $ make upload
perl pulse.pl
/usr/bin/avrdude -V -F -C /etc/avrdude.conf -p atmega168 -P /dev/tts/0 -c stk500v1 -b 19200 -U flash:w:applet/Blink.hex
avrdude: stk500_getsync(): not in sync: resp=0xf0
make: *** [upload] Error 1
The pulse.pl script was the key to making it work in the beginning. It simply toggles dtr to reset the board: Device::SerialPort->new("/dev/ttyS0")->pulse_dtr_on(100);
I'm running gentoo linux, using a straight through db9 cable. LED 13 flicks once on a reset, and flick 2-3 times when i run pulse.pl. It also flicks additional times when I try to upload. Uploading was working fine before, I'm not sure what's changed. Any suggestions?
Tried the parallel port programmer on the off chance that would fix it. However, I couldn't get that to work either. Avrdude says "device not responding".
I don't understand why it's not working. The flicking LED on the board indicates the boot loader is still intact. I've read that rx/tx pins can be indicators of whether the board is still working or not. If I put some leds on those, what kind of blinking should I be looking for?
I've got a Duemilanove that experiences that problem if I try to upload a sketch via USB while also running a BlueSMIRF bluetooth radio off of the protoshield. If I remove the bluetooth radio module I can upload the sketch without any problem. Once uploaded I can power-off and reattach the bluetooth radio.
I will double check to make sure I don't have any applications running that might be affecting my serial port. However, I'm not convinced this is the problem as I get the same error under Linux, where I am positive I don't have any software running that would do that.
If you have multiple serial devices on the board itself you might get the same problem on any OS. I had it with XP/Vista and OS X before removing the extra serial device form the board.
duncan: these errors happen with nothing plugged into the board other than the db9 serial cable to my pc and 9v.
nkcelectronics: The board worked before. I was under the impression that because led 13 flicks normally, and flicks when I try to upload that the bootloader was intact. Is this not so?
