Hey guys, wanted to show off my freeform arduino that fits into a dry-erase marker. Its got a LM7805 regulator, crystal with caps, and reset button on the top of an atmega328 (and a string to pull it back out:P). The first pic shows it running the blink example sketch. Can anyone thing of any good applications? I figure it at least gives good waterproofing.
Heh - nice to see someone doing this kind of thing - have you seen this guy's work?:
http://www.geocities.jp/arduino_diecimila/obaka/project-2/index_en.html
Yeah that one was good inspiration. No clue how he made it that neat though..
You could put an accelerometer in, or at least, a tilt switch, to detect when it has been picked up and is being moved around. This could then send a signal somehow to switch a projector bulb off for a while, or switch the room lights up a bit for a while. Then when you put it back down and it hasn't been moved for a short while, the room light could fade down or the projector could power up again.
Of course, it'd still need to function in its original manner, as a marker.
With an accelerometer in there you could even do crude gesture capture, storing the motions of the marker to a small external SPI FLASH chip as long as the marker was roughly held in a horizontal position (indicating that someone was writing). Then later you could download the gestures and recreate the writing with a "little bit of software" ![]()
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, light sensor, potentiometers, pushbuttons
Here's some off the top of my head;
Datalogger for projectile analysis in ballistics projects
- slap it in a potato, load up the spudgun and perfect your fuelmix.
TV-B-GONE
POV-pen
Speed control for slot-cars
Lights-seeking missile
Encoded pocket transmitter
If you could squeeze the power supply inside it would make a great platform for pranking...
Rolls away when someone tries to grab it
Screams when picked up
Flashes or screams when shaken (because it won't write)
Vibrates when picked up
Randomly rolls around
Screams loudly when thrown or dropped
Randomly pops the cap off
Looks like a natural setup for model airplanes, rockets, small balloon, and similar setups.
Smiley
K, now I'm going to have to do that using a surface mount Amtel. ![]()
Some time back I saw a video of a guy who put an IR led on the tip of a dry erase (replacing the felt) and using the wii's ir camera he made a diy smartboard. You could do something like that, but perhaps with more complexity now that you have an arduino inside.
