FreeIMU serial example giving errors
Hi everyone I just downloaded the freeimu library from : trunk : Code : FreeIMU I wanted to load the FreeIMU_serial example into my arduino mega to calibrate it with the python gui. When I tried to compile it, it gave me these errors :
 FreeIMU_serial:64: error: missing binary operator before token "("
         #if HAS_ITG3200()
FreeIMU_serial:71: error: missing binary operator before token "("
         #if IS_9DOM()
exit status 1
Here is the sketch:
 * FreeIMU library serial communication protocol
#include <ADXL345.h>
#include <bma180.h>
#include <HMC58X3.h>
#include <ITG3200.h>
#include <MS561101BA.h>
#include <I2Cdev.h>
#include <MPU60X0.h>
#include <EEPROM.h>
//#define DEBUG
#include "DebugUtils.h"
#include "CommunicationUtils.h"
#include "FreeIMU.h"
#include <Wire.h>
#include <SPI.h>
float q[4];
int raw_values[9];
float ypr[3]; // yaw pitch roll
char str[256];
float val[9];
// Set the FreeIMU object
FreeIMU my3IMU = FreeIMU();
//The command from the PC
char cmd;
  Wire.begin();
  my3IMU.init(true);
  // LED
  pinMode(13, OUTPUT);
  if(Serial.available()) {
    cmd = Serial.read();
    if(cmd=='v') {
      sprintf(str, "FreeIMU library by %s, FREQ:%s, LIB_VERSION: %s, IMU: %s", FREEIMU_DEVELOPER, FREEIMU_FREQ, FREEIMU_LIB_VERSION, FREEIMU_ID);
      Serial.print(str);
      Serial.print('\n');
    else if(cmd=='r') {
      uint8_t count = serial_busy_wait();
      for(uint8_t i=0; i<count; i++) {
        my3IMU.getRawValues(raw_values);
        sprintf(str, "%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,", raw_values[0], raw_values[1], raw_values[2], raw_values[3], raw_values[4], raw_values[5], raw_values[6], raw_values[7], raw_values[8], raw_values[9], raw_values[10]);
        Serial.print(str);
        Serial.print('\n');
    else if(cmd=='b') {
        #if HAS_ITG3200()
          my3IMU.acc.readAccel(&raw_values[0], &raw_values[1], &raw_values[2]);
          my3IMU.gyro.readGyroRaw(&raw_values[3], &raw_values[4], &raw_values[5]);
        #else // MPU6050
          my3IMU.accgyro.getMotion6(&raw_values[0], &raw_values[1], &raw_values[2], &raw_values[3], &raw_values[4], &raw_values[5]);
        #endif
        writeArr(raw_values, 6, sizeof(int)); // writes accelerometer and gyro values
        #if IS_9DOM()
          my3IMU.magn.getValues(&raw_values[0], &raw_values[1], &raw_values[2]);
          writeArr(raw_values, 3, sizeof(int));
        #endif
    else if(cmd == 'q') {
        my3IMU.getQ(q);
        serialPrintFloatArr(q, 4);
        Serial.println("");
    #ifndef CALIBRATION_H
    else if(cmd == 'c') {
      const uint8_t eepromsize = sizeof(float) * 6 + sizeof(int) * 6;
      while(Serial.available() < eepromsize) ; // wait until all calibration data are received
      EEPROM.write(FREEIMU_EEPROM_BASE, FREEIMU_EEPROM_SIGNATURE);
      for(uint8_t i = 1; i<(eepromsize + 1); i++) {
        EEPROM.write(FREEIMU_EEPROM_BASE + i, (char) Serial.read());
      my3IMU.calLoad(); // reload calibration
      // toggle LED after calibration store.
      digitalWrite(13, HIGH);
      digitalWrite(13, LOW);
    else if(cmd == 'x') {
      EEPROM.write(FREEIMU_EEPROM_BASE, 0); // reset signature
    #endif
    else if(cmd == 'C') { // check calibration values
      Serial.print("acc offset: ");
      Serial.print(my3IMU.acc_off_x);
      Serial.print(",");
      Serial.print(my3IMU.acc_off_y);
      Serial.print(",");
      Serial.print(my3IMU.acc_off_z);
      Serial.print("\n");
      Serial.print("magn offset: ");
      Serial.print(my3IMU.magn_off_x);
      Serial.print(",");
      Serial.print(my3IMU.magn_off_y);
      Serial.print(",");
      Serial.print(my3IMU.magn_off_z);
      Serial.print("\n");
      Serial.print("acc scale: ");
      Serial.print(my3IMU.acc_scale_x);
      Serial.print(",");
      Serial.print(my3IMU.acc_scale_y);
      Serial.print(",");
      Serial.print(my3IMU.acc_scale_z);
      Serial.print("\n");
      Serial.print("magn scale: ");
      Serial.print(my3IMU.magn_scale_x);
      Serial.print(",");
      Serial.print(my3IMU.magn_scale_y);
      Serial.print(",");
      Serial.print(my3IMU.magn_scale_z);
      Serial.print("\n");
    else if(cmd == 'd') { // debugging outputs
      while(1) {
        Serial.print(str);
        Serial.print('\n');
        my3IMU.getQ(q);
        Serial.println("");
        my3IMU.getYawPitchRoll(ypr);
        Serial.print("Yaw: ");
        Serial.print(ypr[0]);
        Serial.print(" Pitch: ");
        Serial.print(ypr[1]);
        Serial.print(" Roll: ");
        Serial.print(ypr[2]);
        Serial.println("");
char serial_busy_wait() {
  while(!Serial.available()) {
    ; // do nothing until ready
  return Serial.read();
const int EEPROM_MIN_ADDR = 0;
const int EEPROM_MAX_ADDR = 511;
void eeprom_serial_dump_column() {
  // counter
  int i;
  // byte read from eeprom
  byte b;
  // buffer used by sprintf
  char buf[10];
  for (i = EEPROM_MIN_ADDR; i <= EEPROM_MAX_ADDR; i++) {
    b = EEPROM.read(i);
    sprintf(buf, "%03X: %02X", i, b);
    Serial.println(buf);
Anyone?
RTIMUlib for Arduino is state of the art, and also free. It works very well.
I'd start by removing those parens.
jremington: RTIMUlib for Arduino is state of the art, and also free. It works very well.
The library is no longer supported.
johnwasser: I'd start by removing those parens.
Could you be more specific. Which parentheses
It doesn't need support. It works.
jremington: It doesn't need support. It works.
Ok Ill try it
