I'm looking for a programmer that is confident with both AVRDUDE and a cross-platform GUI IDE. I'm thinking of Java or Xamarin, but happy to discuss other environments.
It's not a particularly hard project and would probably only take 1 to 2 days.
I don't have enough time at the mo to do it and I need it doing pretty urgently, so makes sense to out-source it. Please PM me if you're interested.
many thanks
Paul
The project is as follows:
Create cross-platform app (with GUI) that allows .elf/.hex/.eep files to be uploaded to Atmega328P via an FTDI cable.
The GUI should have
- A combo box to select the FTDI comm port
- An open button to select a ZIP file containing the .elf,.hex and .eep. (and then unzip ready for uploading)
- An upload button to open comm port, upload, close comm port.
It's only for use with Atmega328P with fixed settings (lock bit etc), so doesn't need to be that open ended or flexible.
It is for use by someone that is non-technical, so should provide good feed back for problems, such as missing files, comm port not able to open etc.
cheers
Paul
