I have a Freenove line following robot but the robot goes to fast. How can I pause the code or put a delay in the code so that the robot only drives ±1 meter and then pause for a while?
I tried to put delays in the code but it does not work, can somebody help me?
This is the code:
#define PIN_SERVO 2
#define PIN_DIRECTION_LEFT 4
#define PIN_DIRECTION_RIGHT 3
#define PIN_MOTOR_PWM_LEFT 6
#define PIN_MOTOR_PWM_RIGHT 5
#define PIN_SONIC_TRIG 7
#define PIN_SONIC_ECHO 8
#define PIN_IRREMOTE_RECV 9
#define PIN_SPI_CE 9
#define PIN_SPI_CSN 10
#define PIN_SPI_MOSI 11
#define PIN_SPI_MISO 12
#define PIN_SPI_SCK 13
#define PIN_BATTERY A0
#define PIN_BUZZER A0
#define PIN_TRACKING_LEFT A1
#define PIN_TRACKING_CENTER A2
#define PIN_TRACKING_RIGHT A3
#define MOTOR_PWM_DEAD 10
#define TK_STOP_SPEED 0
#define TK_FORWARD_SPEED (90 + tk_VoltageCompensationToSpeed )
//define different speed levels
int tk_VoltageCompensationToSpeed; //define Voltage Speed Compensation
#define TK_TURN_SPEED_LV4 (160 + tk_VoltageCompensationToSpeed )
#define TK_TURN_SPEED_LV3 (130 + tk_VoltageCompensationToSpeed )
#define TK_TURN_SPEED_LV2 (-120 + tk_VoltageCompensationToSpeed )
#define TK_TURN_SPEED_LV1 (-140 + tk_VoltageCompensationToSpeed )
float batteryVoltage = 0;
bool isBuzzered = false;
- pinsSetup(); //set up pins*
- getTrackingSensorVal();//Calculate Voltage speed Compensation*
u8 trackingSensorVal = 0;*
trackingSensorVal = getTrackingSensorVal(); //get sensor value*
switch (trackingSensorVal)*
case 0: //000*
motorRun(TK_FORWARD_SPEED, TK_FORWARD_SPEED); //car move forward*
break;*
case 7: //111*
motorRun(TK_STOP_SPEED, TK_STOP_SPEED); //car stop*
break;*
case 1: //001*
motorRun(TK_TURN_SPEED_LV4, TK_TURN_SPEED_LV1); //car turn*
break;*
case 3: //011*
motorRun(TK_TURN_SPEED_LV3, TK_TURN_SPEED_LV2); //car turn right*
break;*
case 2: //010*
case 5: //101*
break;*
case 6: //110*
motorRun(TK_TURN_SPEED_LV2, TK_TURN_SPEED_LV3); //car turn left*
break;*
case 4: //100*
motorRun(TK_TURN_SPEED_LV1, TK_TURN_SPEED_LV4); //car turn right*
break;*
default:*
break;*
void tk_CalculateVoltageCompensation() {
- getBatteryVoltage();*
- float voltageOffset = 7 - batteryVoltage;*
- tk_VoltageCompensationToSpeed = 30 * voltageOffset;*
//when black line on one side is detected, the value of the side will be 0, or the value is 1
u8 getTrackingSensorVal() {
- u8 trackingSensorVal = 0;*
- trackingSensorVal = (digitalRead(PIN_TRACKING_LEFT) == 1 ? 1 : 0) << 2 | (digitalRead(PIN_TRACKING_CENTER) == 1 ? 1 : 0) << 1 | (digitalRead(PIN_TRACKING_RIGHT) == 1 ? 1 : 0) << 0;*
- return trackingSensorVal;*
void pinsSetup() {
- //define motor pin*
- pinMode(PIN_DIRECTION_LEFT, OUTPUT);*
- pinMode(PIN_MOTOR_PWM_LEFT, OUTPUT);*
- pinMode(PIN_DIRECTION_RIGHT, OUTPUT);*
- pinMode(PIN_MOTOR_PWM_RIGHT, OUTPUT);*
- //define ultrasonic moduel pin*
- pinMode(PIN_SONIC_TRIG, OUTPUT);*
- pinMode(PIN_SONIC_ECHO, INPUT);*
- //define tracking sensor pin*
- pinMode(PIN_TRACKING_LEFT, INPUT);*
- pinMode(PIN_TRACKING_RIGHT, INPUT);*
- pinMode(PIN_TRACKING_CENTER, INPUT);*
- setBuzzer(false);*
void motorRun(int speedl, int speedr) {
- int dirL = 0, dirR = 0;*
- if (speedl > 0) {*
- dirL = 0;*
- else {*
- dirL = 1;*
- speedl = -speedl;*
- if (speedr > 0) {*
- dirR = 1;*
- else {*
- dirR = 0;*
- speedr = -speedr;*
- speedl = constrain(speedl, 0, 255); // speedl absolute value should be within 0~255*
- speedr = constrain(speedr, 0, 255); // speedr absolute value should be within 0~255*
- digitalWrite(PIN_DIRECTION_LEFT, dirL);*
- digitalWrite(PIN_DIRECTION_RIGHT, dirR);*
- analogWrite(PIN_MOTOR_PWM_LEFT, speedl);*
- analogWrite(PIN_MOTOR_PWM_RIGHT, speedr);*
bool getBatteryVoltage() {
- if (!isBuzzered) {*
- pinMode(PIN_BATTERY, INPUT);*
- int batteryADC = analogRead(PIN_BATTERY);*
- if (batteryADC < 614) // 3V/12V ,Voltage read: <2.1V/8.4V*
batteryVoltage = batteryADC / 1023.0 * 5.0 * 4;*
return true;*
- return false;*
void setBuzzer(bool flag) {
- isBuzzered = flag;*
- pinMode(PIN_BUZZER, flag);*
- digitalWrite(PIN_BUZZER, flag);*
void alarm(u8 beat, u8 repeat) {
- beat = constrain(beat, 1, 9);*
- repeat = constrain(repeat, 1, 255);*
- for (int j = 0; j < repeat; j++) {*
- for (int i = 0; i < beat; i++) {*
setBuzzer(true);*
delay(100);*
setBuzzer(false);*
delay(100);*
- delay(500);*
void resetCarAction() {
- motorRun(0, 0);*
