FreeRTOS on esp32, sending structure via queue
Hello, I am trying to send structure via queue in FreeRTOS. This is my code:
#include "queue.h"
typedef int taskProfiler;
typedef enum
  eSender1 = 0,
  eSender2,
}DataSource_t;
typedef struct
  uint8_t ucValue;
  DataSource_t eDataSource;
}Data_t;
static Data_t xStructToSend[2] =
  (100, eSender1),
  (50, eSender2)
QueueHandle_t xQueue;
taskProfiler senderTaskProfiler = 0;
taskProfiler receiverTaskProfiler = 0;
  delay(5000);
  Serial.println(xStructToSend[1].ucValue);
  xQueue = xQueueCreate(3, sizeof(Data_t));
  xTaskCreate(vSenderTask, "Sender Task 1", 8192, &(xStructToSend[0]), 2, NULL);
  xTaskCreate(vSenderTask, "Sender Task 2", 8192, &(xStructToSend[1]), 2, NULL);
  xTaskCreate(vReceiverTask, "Receiver Task", 8192, NULL, 2, NULL);
void vSenderTask(void *pvParameters)
  BaseType_t xStatus;
  const TickType_t xTicksToWait = pdMS_TO_TICKS(100);
  Data_t xReceivedStructure;
  memcpy(&xReceivedStructure, &pvParameters, sizeof(pvParameters));
  while(1)
    xStatus = xQueueSend(xQueue, pvParameters, xTicksToWait);
    if(xStatus != pdPASS)
      Serial.println("Could not send to the Queue");
    Serial.println(xReceivedStructure.ucValue);
void vReceiverTask(void *pvParameters)
  BaseType_t xStatus;
  while(1)
    xStatus = xQueueReceive(xQueue, &xReceivedStructure, 0);
    if(xStatus == pdPASS)
      if(xReceivedStructure.eDataSource == eSender1)
        Serial.print("This is from Sender1: ");
        Serial.print("This is from Sender2: ");
      Serial.println("Could not receive data from the queue");
In line "Serial.println(xStructToSend[1].ucValue);" (in void setup()) I get value 0 and I should get 50. The same issue is in line "Serial.println(xReceivedStructure.ucValue);" ( in void vSenderTask(void *pvParameters)). In receiver task i get only values 152 and 160. That looks like I have some error in inicialization structure values. How can I deal with this problem? Thanks in advance for your help.
terminal
Hello
Your array is not initialized correctly, change parenthesis to brackets:
  { 100, eSender1 },
  { 50, eSender2 }
That solved my problem. Thank you very much!
