Freerun mode for multiple analog inputs?
Hi!
I’m working on a project that needs a lot of analog inputs so I’m going to use multiplexers and I need to use all the analog inputs of the Due. From this topic: http://forum.arduino.cc/index.php?topic=224664.0 (code segment from that topic below) I see how to use freerun mode on one analog input.
Is it possible to use freerun for multiple analog inputs and how in that case? I need the smallest amount of latency for my project. Thanks for any help!
int x;                                           // read value
  Serial.begin(57600);                           // initialize the serial port:
  REG_ADC_MR = 0x10380180;                       // change from 10380200 to 10380180, 1 is the PREESCALER and 8 means FREERUN
  ADC -> ADC_CHER = 0x80;                        // enable ADC on pin A0
  unsigned long t = micros();                    // init time an elapsed time, in micro seconds
  for(int i = 0; i < 1000; i++) {
    // instrucction to measure
    while((ADC->ADC_ISR & 0x80)==0);             // wait for conversion
    x = ADC->ADC_CDR[7];                         // read value A0
  t = micros() - t - 2;                          // 2 us is nothing measured time
  Serial.print("Time (us) ");
  Serial.println( ( (double) t / 1000 ), 6 );
  delay(2000);
I figured this out myself, here is a working example that reads from all analog inputs. Time is 5.8µs for one read of all 12 analog inputs (~0.5µs per input). I have to do more tests to see how reliable this method is, for my project I only need 7-bits of precision though.
int x[12]; // read value
int mean[12]; // mean value
byte cdr[12] = {7,6,5,4,3,2,1,0,10,11,12,13}; // cdr indexes
int i, j;
  REG_ADC_MR = 0x10380180; // change from 10380200 to 10380180, 1 is the PRESCALER and 8 means FREERUN
  ADC -> ADC_CHER = 0x3CFF; // enable ADC on all pins
  for(j = 0; j < 12; j++)
    x[j] = 0;
  for(i = 0; i < 1000; i++)
    while((ADC->ADC_ISR & 0x3CFF)==0); // wait for conversion
      x[j] += ADC->ADC_CDR[cdr[j]]; // read value
    mean[j] = x[j] / 1000;
  Serial.print("Time (us): ");
  for(j = 0; j < 12; j++) {
    Serial.print("Value");
    Serial.print(j);
    Serial.print(": ");
    Serial.println( mean[j]/32 );
  delay(2000);
