Freescale pressure sensor, model MPXV5010GP
I'm hoping that someone could help me out there, I'm trying to interface with a Freescale pressure sensor, model MPXV5010GP with a Sanguino (w/ breakout board).
I've followed the notes found at http://spiffie.org/electronics/archives/microcontrollers/Arduino%20and%20Freescale%20MPX%20Pressure%20sensors.html
On the sensor, I have pin Pin 2 connects to +5 (VCC). Pin 3 connects to Analog #0 (Pin 24 on the Sanguino), Pin 4 connects to Ground (GND).
When I measure the voltage on Pin24 and GND I get ~690mV which is what I'd expect as I understand this is the offset voltage for the sensor. However, using the following code:
// AnalogInput
int potPin = 24; // select the input pin for the potentiometer int val = 0; // variable to store the value coming from the sensor
void setup() { Serial.begin(9600);
void loop() { val = analogRead(potPin); // read the value from the sensor // stop the program for some time Serial.print(val); }
I get readings of 336-350, which I'm calculating to 1.75v. I have a tube running from the port on the sensor to open air... then I push the tube in a glass of water.
a.) Why is the AnalogRead function giving me 330-360, when I (think) i should be getting around 120 for the .6v. b.) Why is there no voltage change as the tube gets pushed into the water?
int potPin = 24;
If you have the pressure sensor connected to the Arduino's analog input 0, you'll need to write:
int potPin = 0;
Pin numbers are Arduino numbers, not the AVR chip's pin numbers.
Thanks.... but I'm using a Sanguino so it's actually pin 24 for analog 7. Although I see put the wrong pin in my description, pin 3 is actually connected to Analog 7, or pin 24.
My Sanguino uses 0 to 7 when calling analogRead()...
Yes, the argument to "analogRead()" is an analog channel number, not a physical pin number. So for the first analog input channel, you need "analogRead(0)", and so on.
