Freetronics Ethermega and the "Eleven"
This is getting annoying, and I shall ask Freetronics as well. But I feel it may be better to ask others as well.
Some of you may have read my other posts about my "multi-day alarm clock".
I may be faced with the fact that there aren't enough input and output lines.
I only need another output and enough inputs to allow about 8 keys. I'm picking 8 because it is a power of 2. I don't think 4 would be enough, but it may be.
Alas this would exclude the actual clock menu buttons, which I would have to accept as not accessible with 4, but could be with 8.
Anyway, I am just looking for now.
Not sure, but feel free to add links to them.
If we knew more, we may be able to help.
You may be able to use analogue inputs with resistors to give unique key ids.
Hi AWOL.
Link for my thread:
Believed pins remaining for use with what I have:
Buttons - pins used:
5, 10, 11, 4, 14, 15
LCD - pins used:
8, 9, 7, 6, 2, 3
RTC - pins used:
18, 19
Buzzer pin:
17 - the light, 16 - the other relay (alarm0)
Un-used pins:
0, 1, 12, 13 (LED)
Now, 0 and 1 are RX and TX if I understand the pin outs correctly.
Thus I could get a mini, micro, or what ever. From that one, I could put a "big keyboard" with lots of buttons to press.
That leaves 12 left. That's digital pin 12. So that could be my third output.
Ok, I could take 16 off as an output and use it as an input (analogue) and get a heap of keys on it.
Sure, a possibility.
What's using all the other pins? Mega based boards have fifty-something digital pins.
Sorry,
This is what I have:
It is called an "eleven" which is basically an UNO.
The alarm clock leaves bugger all pins left.
I am learning that the PHI-2 shield has some bad designs in how the pins are "broken out" for user access.
So, if you look at my second post, my project is there and a list of which pins I THINK are usable.
I noticed that pin 16 is an analogue I/O line and though it is "Free" where it is positioned I mistakenly used it as an output.
Luckily I can negate this error easily. But getting to the other pins is annoying.
So as I have realised that 16 is an analogue input it may be ok.
But I am just wondering/asking if the MEGA would be shield compatible so I could take the shield off this project and plug it into the MEGA and have it work.
Enough for at least 9 keys - have you got nine keys connected?
There are all sorts of tricks you can use (matrix, shift register, resistor ladder...), but a schematic would help.
AWOL,
Yes, I accept what you say, but there is a "catch".
Those pin buttons are for the PHI-2 shield.
It is not nice that John did it that way. I don't know how easy it would be to hack the board to allow analogue input for the keys.
The "Schematic" is pretty simple - apart from the shield. Pin 17 is the output to drive one of the two relays.
What is a PHI-2 shield?
Who is John?
Have you adequately berated, nay, castigated him for his thoughtlessness?
PHI-2 shield:
I want to work on resolving the problem rather than "blaming" someone. Coz I guess it is just as much my fault for buying it.
It is just that it is a handy way to get the clock working and the sketch was a "multi day alarm clock".
You could build a simple intermediate shield to sit between Arduino and the PHI-2 shield to breakout the button pins and make better use of them.
That would be my first thought.
Heck, that was my first thought.
edit: My second thought, on re-reading was "what are the analogue pins doing?"
edit2: Re-re-reading they're used. OK.
Yeah, it is possible.
I guess a couple of strips of vero-board with extenders and access pins. Then I cut the tracks where needed.
Yeah, not rocket science. I'll look into the idea.
