Freeze Arduino Duemilanove
Salve a tutti ragazzi!
Ho scritto questo piccolo codice che permette di inserire in cloud le informazioni ricavate da un sensore pir e da una fotoresistenza.
Il tutto funziona correttamente per un paio di ore.. dopo si blocca la scheda non trasmettendo piu i dati... sapreste indicarmi una soluzione?
#include <SPI.h>
#include <Ethernet.h>
#include <SimpleTimer.h>
#define MOVEMENT_SENSOR 2
#define LIGHT_SENSOR A0
// Local Network Settings
byte mac[]     = { 0xD4, 0x28, 0xB2, 0xFF, 0xA0, 0xA1 };
// ThingSpeak Settings
byte server[]  = { 184, 106, 153, 149 }; // IP Address for the ThingSpeak API
String writeAPIKey = "KEY_HERE";    // Write API Key for a ThingSpeak Channel
EthernetClient client;
SimpleTimer timer;
boolean sended = false;
boolean lastConnected = false;
        /*PIN settings*/
        pinMode(MOVEMENT_SENSOR,INPUT);
        /*Timers Section*/
        timer.setInterval(60000,updateStats);
        Serial.println(Ethernet.begin(mac));
void loop(){
        timer.run();
        updateMovementSensor();
        if (client.available()) {
                char c = client.read();
                Serial.print(c);
        // if the server's disconnected, stop the client:
        if (!client.connected() &&lastConnected) {
                /*Serial.println();
                Serial.println("disconnecting.");*/
                client.stop();
   lastConnected = client.connected();
void updateMovementSensor(){
        byte PirState =  digitalRead(MOVEMENT_SENSOR);
        PirState = 1-PirState; /*Invert the vale*/
        if(PirState > 0 && sended == false){
                String movementSensor = String(PirState,DEC);
                updateThingSpeak("field2="+movementSensor);
                sended = true;
        }else if(PirState == 0){
          sended = false;
void updateStats(){
        String lightValue = String(analogRead(LIGHT_SENSOR),DEC);
        updateThingSpeak("field1="+lightValue+"&field2=0");
void updateThingSpeak(String tsData)
  if (client.connect(server, 80))
    Serial.println("Connected to ThingSpeak...");
    client.print("POST /update HTTP/1.1\n");
    client.print("Host: api.thingspeak.com\n");
    client.print("Connection: close\n");
    client.print("X-THINGSPEAKAPIKEY: "+writeAPIKey+"\n");
    client.print("Content-Type: application/x-www-form-urlencoded\n");
    client.print("Content-Length: ");
    client.print(tsData.length());
    client.print("\n\n");
    client.print(tsData);
    /*Serial.println("Connection Failed.");
    Serial.println();*/
Ci sono tantissime discussioni aperte sui problemi di freeze causati dalla scheda Ethernet o, a quanto pare, dalla libreria che la gestisce. Ti consiglio di cercarle e di leggertele per evitare di trattare argomenti già discussi ampiamente. Ce n'era anche una molto recente, a cui avevano contribuito in diversi.
La prima delle soluzioni è utilizzare l'ultima versione dell'IDE (1.0.5) che riunisce le modifiche alla libreria Ethernet fatte già dalla versione 1.0
ciao e grazie per le risposte... sto utilizzando proprio quella versione per mac osx...
ho trovato questo link.. ma non so se può essermi davvero utile:
http://forum.arduino.cc/index.php?topic=68624.15
Ho analizzato il file w5100.h ed effettivamente con la versione del mio compiler(1.0.5) è già contenuta la modifica citata nel link che ho postato.
Ci sono altre soluzione a questo problema?
Ho appena applicato l'esempio "WebClientRepeating" prensente sul sito al mio caso.. ]:smiley:
  Repeating Web client
 This sketch connects to a a web server and makes a request
 using a Wiznet Ethernet shield. You can use the Arduino Ethernet shield, or
 the Adafruit Ethernet shield, either one will work, as long as it's got
 a Wiznet Ethernet module on board.
 This example uses DNS, by assigning the Ethernet client with a MAC address,
 IP address, and DNS address.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 created 19 Apr 2012
 by Tom Igoe
 http://arduino.cc/en/Tutorial/WebClientRepeating
 This code is in the public domain.
#include <SPI.h>
// assign a MAC address for the ethernet controller.
// fill in your address here:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
// fill in an available IP address on your network here,
// for manual configuration:
IPAddress ip(10,0,0,20);
// fill in your Domain Name Server address here:
IPAddress myDns(1,1,1,1);
// initialize the library instance:
unsigned long lastConnectionTime = 0;          // last time you connected to the server, in milliseconds
boolean lastConnected = false;                 // state of the connection last time through the main loop
const unsigned long postingInterval = 30*1000;  // delay between updates, in milliseconds
String stringLightValue;
  // start serial port:
  // give the ethernet module time to boot up:
  // start the Ethernet connection using a fixed IP address and DNS server:
  Ethernet.begin(mac, ip, myDns);
  // print the Ethernet board/shield's IP address:
  Serial.print("My IP address: ");
  Serial.println(Ethernet.localIP());
  // if there's incoming data from the net connection.
  // send it out the serial port.  This is for debugging
  // purposes only:
    Serial.print(c);
  // if there's no net connection, but there was one last time
  // through the loop, then stop the client:
  if (!client.connected() && lastConnected) {
    client.stop();
  // if you're not connected, and ten seconds have passed since
  // your last connection, then connect again and send data:
  if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
    stringLightValue = String(analogRead(A0),DEC);
	updateThingSpeak("field1="+stringLightValue);
  // store the state of the connection for next time through
  // the loop:
// this method makes a HTTP connection to the server:
void updateThingSpeak(String tsData) {
  // if there's a successful connection:
  if (client.connect(server, 80)) {
    // note the time that the connection was made:
    lastConnectionTime = millis();
  else {
    // if you couldn't make a connection:
    Serial.println("connection failed");
    client.stop();
Stasera flasho e lascio in funzione per tutta la notte... speriamo... 8)
Allora, dopo aver verificato anche sul mio secondo pc la prensenza della modifca sul file w5100 ho apportato una piccola modifica al firmware.
Salvo lo stato del sensore PIR in una variabile ed invio con una sola chiamata i dati in cloud.
 Circuit:
 created 19 Apr 2012
 by Tom Igoe
#include <SPI.h>
#define PIR_SENSOR 2
byte mac[] = {
//IPAddress ip(1);
String pirValue;
  pinMode(PIR_SENSOR,INPUT);
  Ethernet.begin(mac);
  // purposes only:
  byte PirState =  digitalRead(PIR_SENSOR);
  if(PirState > 0){
   pirValue =  String(PirState,DEC);
   Serial.println(pirValue);
    Serial.print(c);
    client.stop();
	updateThingSpeak("field1="+stringLightValue+"&field2="+pirValue);
        pirValue = "0";
  // the loop:
  else {
    client.stop();
Vediamo cosa succede da ora in poi.... :drooling_face:
ho aggiunto anche la temperatura per aumentare la mole di pacchetti..
 Circuit:
 created 19 Apr 2012
 by Tom Igoe
#include <SPI.h>
#define TEMP_SENSOR A1
byte mac[] = {
//IPAddress ip(1);
String pirValue;
int tempC =0;
String tempcString;
  // purposes only:
  if(PirState > 0){
   //Serial.println(pirValue);
  tempC = analogRead(TEMP_SENSOR);           //lettura valore del sensore
tempC =(int) (5.0 * tempC * 100.0)/1024.0;  //conversione del dato analogico
  tempcString = String(tempC,DEC);
    Serial.print(c);
    client.stop();
	updateThingSpeak("field1="+stringLightValue+"&field2="+pirValue+"&field3="+tempcString);
        pirValue = "0";
  // the loop:
  else {
    client.stop();
ragazzi sto trasmettendo da ieri sera alle 21 circa! sembra andare ancora tutto bene!
Cattive notizie... mi ero gasato... =(... a questo punto credo che un reset della scheda sarebbe l'ideale..
ho trovato a questo link: http://forum.arduino.cc/index.php/topic,35155.0.html una risposta di Banzi in persona:
Ciao.
Ci sono 4 metodi:
  1. Chiudere e riaprire la porta seriale , questo fa resettare il processore. e' la tecnica che usiamo per caricare i programmi sull'arduino quando premi "Upload to IO Board"
  2. Collegare un piedino digitale al piedino "Reset" sulla scheda ma la Atmel non garantisce che funzioni (la spiegazione è abbastanza tecnica e rasenta la masturbazione mentale)
  3. forzare il processore a fare "goto $00" però questo lascia la ram, i timer e gli interrupt sporchi... cioè non è garantito che il programma riparta bene.
  4. Raccomandato da Atmel. Attivare il "watchdog timer" e aspettare che si resetti.
    Il "cane da guardia" è un timer che serve a resettare un processore che si sia incastrato per un problema software. Il timer, una volta attivato, resetta il processore a meno che non venga fatto ripartire... perciò in un'applicazione che deve mantenere un certo livello di affidabilità, il programma fa ripartire il timer regolarmente ... dovesse mai incepparsi allora dopo pochi millisecondi il processore si resetta. Aggiungi questo all'inizio tuo sketch Arduino
    Code:
    #include <avr/io.h>
    #include <avr/wdt.h>
#define Reset_AVR() wdt_enable(WDTO_30MS); while(1) {}
mentre nel punto dove vuoi resettare scrivi:
Code:
Reset_AVR();
Nota: Apprezzo molto l'entusiasmo con cui molti si danno da fare per rispondere, senza di voi Arduino non esisterebbe. Però certe volte non sparate le risposte a caso perchè se chi ha fatto la domanda è un principiante poi si confonde e non capisce più
Proverò a resettare seguendo quanto consigliato da Atmel...
L'autoreset mediante un piedino mandato a LOW non ti garantisce un tempo di tenuta del pin di reset a livello basso sufficiente per il reset. Meglio il watchdog.
Hai cercato quella discussione che ti dicevo?
si leo... la modifica al file w5100.h era già presente...
proverò con il watchdog...
che ne dici se resetto la board ogni 2 ore?
Imposto un timer con questa libreria Arduino Playground - HomePage
Cosa ne pensi? esiste un event handler che rileva il blocco o qualche soluzione migliore? :astonished:
Non conosco bene quella lib ma mi pare che usi millis per schedulare i compiti, come fa anche il mio looper.
Se però il codice si blocca da qualche parte, quella lib non funziona più. Ti serve uno scheduler basato su un timer o sul watchdog. Io ho scritto il leOS basato sul timer 2 ed il leOS2 basato sul watchdog. Entrambe sono "immuni" ai blocchi del codice principale e possono anche resettare l'Arduino.
Ma non so se è conveniente un reset ogni 2 ore diciamo... preventivo.
Alternativamente potresti utilizzare una soluzione basata sul chip ENC28J60, ma si tratta di scrivere buona parte del codice da capo e fare i conti con la libreria specifica che occupa più spazio di quella ufficiale.
Però non mi risulta che si blocchi.
Esempio Low cost Ethernet shield with ENC28J60 - Open Electronics - Open Electronics
leo72:
grande! sto leggendo il documento di le0S2 per riavviare la scheda..
Utilizzerò il tuo esempio
This is a simple sketch to demonstrate the use of leOS2, a
<l>ittle <e>mbedded <O>perating <S>ystem 2
leOS2 is not a complete OS nor an RTOS as you usually know but it's a simple
scheduler to schedule little works in background, so that you can forget about
them.
This sketch tests the usage of the method reset() called by another task.
More info on the scheduler and the methods can be found into the README file.
Written by Leonardo Miliani <www.leonardomiliani.com>
This code and the leOS2 library are free software; you can redistribute
and/or modify them under the terms of the GNU General Public License as
published by the Free Software Foundation; either version 3.0 of the License,
or (at your option) any later version.
The leOS2 library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
#include "leOS2.h" //include the scheduler
leOS2 myOS; //create a new istance
const byte LED = 13; //LED on pin 13
//setup routine
    myOS.begin(); //initialize the scheduler
    pinMode(LED, OUTPUT); //pin as output
    myOS.addTask(reset, myOS.convertMs(10000)); //add a task to be executed after 10 seconds
    blink3times(); //blink 3 times the LED on pin 13
//main loop - it's empty
//reset the microcontroller
void reset() {
    myOS.reset();
void blink3times() {
    for (byte i=0; i<3; i++) {
        digitalWrite(LED, HIGH);
        delay(250);
        digitalWrite(LED, LOW);
        delay(250);
ogni quanto mi consigli di riavviarla?
Grazie
Secondo me più che a tempo, dovresti resettare la scheda a necessità.
Metti una variabile globale che viene ad esempio incrementata oppure resettata dal codice posto subito dopo il punto in cui generalmente si blocca tutto. Se il task vede che questa variabile non è stata resettata o non è aumentata di valore, resetta tutto. Il check puoi farlo 1 volta al minuto oppure 1 volta all'ora ecc..
il problema è quello... non so dove si blocca trattandosi di un problema dello shield ethernet.. al massimo posso metterlo quando effettuo la request HTTP...
Fai dei test, usando la seriale come monitor di debug e spedendo da codice un pò di scritte varie. Esempio:
"leggo xxxx"
"ricevuta richiesta http"
"spedisco pagina"
ecc...
ok perfetto, ad ogni modo ho applicato la tua leOS2 al mio progetto:
Ho creato un flag che ad inizio loop viene settato sempre a false, alla fine del loop invece a true.
Nel caso in cui rilevo lo stato del flag a false avvio il reset.
Guarda qui cosa ne pensi:
	My Lab Project
	Programmed By Antonio Blescia
	State: Alpha
			2013-07-09
/*Library Section*/
#include <SPI.h>
#include <leOS2.h> //include the scheduler
/*Sensor Section*/
/*Network Settings*/
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
/*ThingSpeak proprieties*/
/*WatchDog Manager Section*/
bool allRight = false;
leOS2 Controller;
String pirValue;
int tempC =0;
String tempcString;
  Controller.begin();
  Controller.addTask(reset, Controller.convertMs(10000)); //add a task to be executed after 10 seconds
  allRight = false;
  /*Pir Sensor Reading*/
  if(PirState > 0){
  /*Temperature Sensor Reading and Parsing*/
    Serial.print(c);
    client.stop();
        pirValue = "0";
  // the loop:
  allRight= true;
  else {
    client.stop();
void reset() {
    if(!allRight)Controller.reset();
