I’m having an issue where my program runs a loop that performs calculations. Around the 20th loop the calculations freeze (uncertain exactly which loop due to delay in serial out for my debugging).
The error manifests between line 110 and line 168 (although it could be caused by a call outside that range). When I comment out this region of the code it runs fine.
My shotCounter ranges between 0 and 3200. I used excel to see the values of all my float variables. The float variables have up to 7 characters (including decimal point) and have a max value of 719.775.
// define variables to read into from SF30 laser distance
float sfDistance;
int Byte_L, Byte_H;
unsigned long myYawSteps = 400*4; // This is a 400 step motor with two Eighth Steps = quarter step
unsigned long myPitchSteps = 400*4; // This is a 400 step motor with two Eighth Steps = quarter step
* scanRoom function - what we've been waiting for...actually scan the room
void scanRoom() {
DEBUG_PRINTLN(F("Start room scan"));
//Define Variables
float range,azimuth,elevation;
float degPerYawStep = float(360)/myYawSteps;
float degPerPitchStep = float(360)/myPitchSteps;
unsigned long shotCounter = 0;
unsigned int bufferCounter = 0;
unsigned long calculatePosition = 0;
char readingBuffer [9]; //Need 8 + 1 for trailing null from dtostrf
char lineOutputBuffer [31];
float measurementBuffer [128]; //each float takes up 4 bytes
//test varialbes to delete later
//float testrange = 39.999;
//float testazimuth = 99.9999;
//float testelevation = 100.99;
float testintensity = 256.0;
//Warmup the SF30
warmupSF30();
//Make sure the motors are not sleeping
digitalWrite(slpPin,HIGH);
//Open the SD card
DEBUG_PRINTLN(F("Start SD card"));
delay(10);
//For now, overwrite old file...need file increment function
if (SD.exists("OL1.CSV")) {
//DEBUG_PRINTLN("Can access SD card, but can't open new file");
//delay(1); //let bluetooth catch up
SD.remove("OL1.CSV");
delay(100);
myFile = SD.open("OL1.CSV", FILE_WRITE);
myFile.println("Range,Azimuth,Elevation");
myFile.close();
//Begin scanning procedure
//Turn the pitch motor 1 full turn while taking measurements
//Write to SD card every 512 Bytes
//Turn azimuth motor 1 'step' for each pitch motor turn
//Turn on the SF30
sf30_serial.print("#Y");
delay(10);
//myFile.println("Range,Azimuth,Elevation,Intensity");
//myFile.close();
DEBUG_PRINTLN(F("Scanning"));
delay(100); //let bluetooth catch up
//Turn Azimuth
//for(int aloop = 0; aloop < myYawSteps; aloop++) {
for(int aloop = 0; aloop < 2; aloop++) {
// Calculate the azimuth for this loop
//azimuth = float(aloop)*degPerYawStep;
//Turn Pitch
for(int ploop = 0; ploop < myPitchSteps; ploop++) {
//for(int ploop = 0; ploop < 16; ploop++) {
// Take a measurement
//If there are more than 1 reading (2 bytes) then we have gotten ahead of ourselves and need to clear old data
while (sf30_serial.available() > 2) { //If there are more than 1 measurement to be read
Byte_H = sf30_serial.read();
while (!sf30_serial.available()); //Don't get off order, wait for second bit.
Byte_L = sf30_serial.read();
//do nothing with this data, but throw it away as old data
while (!sf30_serial.available()); //Wait until data is available
range = (float(Byte_L))/256 + Byte_H;
//if the range is over max distance of 50m try again one time
if(range > 50.0) {
measurementBuffer[shotCounter % 128] = range;
//add readings to sdBuffer in 32 byte increments
//8 range 1 ',' 8 azimuth 1 ',' 8 elevation 1 ',' 3 intensity 1 'lf' 1'cr'
//The (number of cycles)(bytes output per cycle) needs to have a factor of 512
//readingBuffer is 128 floats which calculates 128 rounds of 32 bytes total
//If we are at the end of the buffer shotcounter % 128 = 127
//Send the buffer to the sd card
if (shotCounter % 128 == 127) {
//DEBUG_PRINTLN("Write Loop");
//delay(100);
for (int bb = 0; bb < 128; bb++) {
//DEBUG_PRINT(" ");
//DEBUG_PRINTLN(freeMemory());
calculatePosition = shotCounter - 127 + bb;
DEBUG_PRINT(" ");
DEBUG_PRINT(calculatePosition);
delay(10);
if ((calculatePosition) < myPitchSteps) { //if calculatePosition < 1600
elevation = float(calculatePosition)*degPerPitchStep;
azimuth = float(0); //this is the first pitch turn...so azimuth is still 0
else {
calculatePosition = calculatePosition % myPitchSteps;
DEBUG_PRINT(" ");
delay(10);
elevation = float((calculatePosition))*degPerPitchStep;
calculatePosition = calculatePosition/myPitchSteps;
DEBUG_PRINT(" ");
delay(10);
azimuth = float((calculatePosition))*degPerYawStep;
calculatePosition = (shotCounter % 127) + bb;
DEBUG_PRINT(" ");
delay(10);
dtostrf(measurementBuffer[calculatePosition],8,4,readingBuffer);
//dtostrf(float(2),8,4,readingBuffer);
for (int br = 0; br < 8; br++) {
lineOutputBuffer[br] = readingBuffer[br];
lineOutputBuffer[8] = ',';
dtostrf(azimuth,8,4,readingBuffer);
for (int ba = 0; ba < 8; ba++) {
lineOutputBuffer[ba+9] = readingBuffer[ba];
lineOutputBuffer[17] = ',';
dtostrf(elevation,8,4,readingBuffer);
for (int be = 0; be < 8; be++) {
lineOutputBuffer[be+18] = readingBuffer[be];
lineOutputBuffer[26] = ',';
dtostrf(testintensity,5,0,readingBuffer);
for (int ba = 0; ba < 3; ba++) {
lineOutputBuffer[ba+27] = readingBuffer[ba+2];
lineOutputBuffer[30] = ' ';
lineOutputBuffer[31] = 10;
//write one line at a time to save memory
myFile.write(lineOutputBuffer,32);
//Step the pitch motor forward 1 step
//For now, run forward 2 eighth steps to get quarter step...need improvement
StepMotorForward(1);
//Increment the shot counter every time we take a shot
shotCounter += 1;
} //end pitch loop
//DEBUG_PRINTLN("Yaw Loop");
//Once every yaw cycle save the file in case of crash
myFile.flush();
// Run the Yaw motor forward 1 step since the pitch has run a full rotation
StepMotorForward(2);
} //end azimuth loop
//Make sure the motors are sleeping
digitalWrite(slpPin,LOW);
myFile.close();
delay(100);
DEBUG_PRINTLN(F("Write Complete"));
I’m grasping at straws trying to figure out why this is freezing. Also, I feel like there should be a more efficient way to calculate this. I am rotating my pitch motor 1600 steps. For every step I capture a distance. Then I write the distance, the pitch angle, the azimuth angle (1 azimuth step per 1600 pitch steps), and intensity (if available). In order to save precious memory I am trying to store 128 distance measurements. Then once those are collected I’m trying to calculate the azimuth and pitch that associate with that reading. I take one line of those and send to SD card and repeat.
