Freezes on download
Hello Arduino Team,
I got an Arduino Duemilanove from the MakerShed the other day as part of the Arduino Starter Kit and whenever I try to download a program the application freezes. I have already checked the board and the faq only to find that this problem could be caused by an already running application. I quickly launched task manager to find that the solution to my problem was not there. Since then I have tried programing my Arduino on 3 different computers running 3 different OSs and still coming up with the same result on all of them. I have read many tutorials and I believe that I am doing everything correctly but it still isn't syncing. Whenever I plug in my Arduino, all the proper lights come on so I don't think it is my board. I triple checked that I was using the right com port so it can't be that. I hope that you can help me.
  • Cornboy3
BUMP
download? upload…?
So you click “upload sketch” and the arduino ide freezes?
Yes that is exactly it. whenever I press the upload button, the IDE just completely freezes and I have to manually end the process.
which version of the IDE? atmega168 or 328 on the Arduino?
and set upload.verbose=true in the preferences.txt and post the last lines of the command line
I have exactly the same problem im running windows xp with a Diecimila board.
I have a similar problem.
I have the Catalyst Pack with Seeeduino Board I am running XP (Same thing seems to happen on my Vista box too) Board is a Seeeduino v1.1 IDE is Arduino v15
The board has three LEDs lit: PWR - Green, on continously TX - Red, flashing (sometimes it stops, not sure if it is anything to do with the issue). Slot 13 (?) - Green, flashing. This isnext to R5 (I think it is the Slot 13 LED, when I put an LED in Slot 13 it flashes at the same rate).
I followed instructions as per the getting started (including setting up the USB Serial driver) IDE is using the Diecimila/Deumilenove w/Atmega168 setting If I click on the serial monitor I get a series of boxes (says it is 9600 baud). If I load the blink example and click "upload to board" the IDE hangs.
Stuck and dissappointed at falling at the first hurdle :(
Can anyone give my any pointers? Thanks
Tom
Running from the bat file:
D:\Dev Tools\arduino-0015>run.bat
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
Binary sketch size: 976 bytes (of a 14336 byte maximum)
Terminate batch job (Y/N)? y
Anbody got any suggestions?
People are saying that I need to select Diecimila from the Tools -> Boards menu however I am using Wiring 0018 and it doesnt have a Boards option in the tools menu just firmware and Serial port...
Why don't you just download and install Arduino IDE? http://arduino.cc/en/Main/Software
I have the Atmega 328 in an Arduino Duemilanove.
I am running the standard IDE.
I will try running the IDE in verbose mode.
