FreqMeasure LiquidCrystal Library Coding Error
Hi, I was doing a project on a speed sensor and looked for a code. I found one downloaded the libraries it specified but an error came up. Code:
#include "FreqMeasure/FreqMeasure.h"
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  Serial.begin(57600);
  lcd.begin(16, 2);
  lcd.print("Freq:");
  lcd.setCursor(10,0);
  lcd.print("Speed:");
  FreqMeasure.begin();
double sum=0;
int count=0;
  if (FreqMeasure.available()) {
    // average 30 readings together
    sum = sum + FreqMeasure.read();
    count = count + 1;
    if (count > 30) {
      float frequency = FreqMeasure.countToFrequency(sum / count);
      float spd = frequency / 19.49; //conversion from frequency to kilometers per hour (sorry, imperial guys :)
      //to improve speed, we update only the bottom row of the LCD
      lcd.setCursor(0, 1);
      lcd.print("                ");
      lcd.print(frequency);
      lcd.print("Hz");
      //lcd.print("       ");
      lcd.setCursor(8,1);
      lcd.print(spd);
      lcd.print("km/h");
      sum = 0;
      count = 0;
}/code]
The error:
Arduino: 1.8.3 (Mac OS X), Board: "Arduino/Genuino Uno"
/var/folders/7q/2mrctx594tz5s16j969ffptr0000gn/T/arduino_modified_sketch_241204/sketch_jul02a.ino:1:37: fatal error: FreqMeasure/FreqMeasure.h: No such file or directory
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
Can someone help me?
Can someone help?
Where did you put the library when you installed it? The library should be in the libraries folder in your sketchbook folder. And the #include line should be. #include <FreqMeasure.h>
Which you forgot to tell us about.
Can someone help?
Sure thing. What do you need help with?
this is the error:
Downloads/FreqMeasure-1.2.0/FreqMeasure/FreqMeasure.ino:2:37: fatal error: FreqMeasure/FreqMeasure.h: No such file or directory
 #include <FreqMeasure/FreqMeasure.h>
exit status 1
/code]
When I downloaded it I clicked ADD .ZIP Library and it didn't work
I did that but, nothing changed there is still the same error. Maybe it is the library these are the libraries:
LiquidCrystal: https://playground.arduino.cc/Main/LiquidCrystal
FreqMeasure: https://github.com/3zuli/HB100_test/tree/master/HB100_LCD_Output/FreqMeasure
this is the error that comes up:
Arduino/libraries/LiquidCrystal/LiquidCrystal.cpp:6:22: fatal error: WProgram.h: No such file or directory
 #include "WProgram.h"
Multiple libraries were found for "FreqMeasure.h"
 Used: /Users//Documents/Arduino/libraries/FreqMeasure-master
 Not used: /Users/Documents/Arduino/libraries/FreqMeasure-1.2.0
Multiple libraries were found for "LiquidCrystal.h"
 Used: /Users//Documents/Arduino/libraries/LiquidCrystal
 Not used: /Users//Documents/Arduino/libraries/NewliquidCrystal
 Not used: /Users//Downloads/Arduino.app/Contents/Java/libraries/LiquidCrystal
exit status 1
/code]
The proper LiquidCrystal library ships with the IDE. Delete this ancient version.
