Hello, I am currently doing a project where I would like to analyze the frequency of the sound of a chain dragging across concrete.
I have this component: http://www.freetronics.com/products/microphone-sound-input-module#.UVxXmKKceSo
connected to an Arduino Duemilanove w/ ATMega 328.
It says it can output Sound Pressure Level (which I am assuming is loudness [dB]) and the raw audio waveform.
When I run an analog read on the MTC output in DEC with this code:
const int micSensor = A0; // the SPL output is connected to analog pin 0
Serial.begin(38400);
Serial.println(analogRead(micSensor), DEC);
delay(10); // delay to avoid overloading the serial port buffer
I am getting numbers such as this:
331
379
369
351
359
347
352
370
319
401
324
343
409
378
351
340
339
384
350
336
393
331
348
360
313
348
334
360
368
317
385
343
320
386
322
374
330
319
344
317
334
360
310
381
342
322
363
313
334
346
317
356
313
312
390
318
347
320
344
359
333
311
382
293
327
345
I wondering if anyone can guide me in trying to save the output of this device to an audio file to an SD card so I can perform further analysis with a program called Audacity (http://audacity.sourceforge.net/). Or if you know of any methods/libraries to get the output in the serial monitor in Hz.
I already have an SD Card module that I have interfaced with the arduino and have successfully been able to read/write to a text file.
Thanks! Please ask if you need clarification.
