Hi all, looking for help with a code error. (I can handle the electronics but code is not my strong point).
I have copied manually the Frequency Counter source code from the book "Arduino Projects for Amateur Radio" and when I do a verify I get the following error;
"FreqCounter" has not been declared.
I have attached my source code and wonder if anyone can give me some guidance please.
Hi, thanks for the reply. Yes I did download the FreqCount.h library.
I re-posted my original message with a different attachment as I realised quickly that the wrong file had been attached. I do not see the variable frq in my set up.
The only message I get is a per first post - "FreqCounter" has not been declared.
I appreciate any help, I am not to good at code and would like to get this working for my transceiver project.
Odd, when I compile your code, I get a lot of errors (it helps to click the "copy error message" button)
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\Brian\Downloads\Transceiver_VFO_Display\Transceiver_VFO_Display.ino: In function 'void loop()':
Transceiver_VFO_Display:80:3: error: 'FreqCounter' has not been declared
FreqCounter::f_comp=CALIBRATION; // Calibrate with known source.
Transceiver_VFO_Display:81:3: error: 'FreqCounter' has not been declared
FreqCounter::start(GATETIME); // Count pulses for specified gating period.
Transceiver_VFO_Display:83:10: error: 'FreqCounter' has not been declared
while (FreqCounter::f_ready == 0)
Transceiver_VFO_Display:85:12: error: 'FreqCounter' has not been declared
dataIn = FreqCounter::f_freq;;
C:\Users\Brian\Downloads\Transceiver_VFO_Display\Transceiver_VFO_Display.ino:77:7: warning: unused variable 'i' [-Wunused-variable]
int i;
C:\Users\Brian\Downloads\Transceiver_VFO_Display\Transceiver_VFO_Display.ino: At global scope:
Transceiver_VFO_Display:122:1: error: expected declaration before '}' token
Using library FreqCount-master at version 1.3 in folder: C:\Users\Brian\Documents\Arduino\libraries\FreqCount-master
Using library LiquidCrystal at version 1.0.7 in folder: C:\Users\Brian\Documents\Arduino\libraries\LiquidCrystal
exit status 1
I don't know which FreqCount library you are using but the one I have uses FreqCount.begin() and available() and read(). Look at the example code that came with the library (File->Examples->FreqCount->LCD Output")
Hi all, thanks for all the answers and questions. I have downloaded a different FreqCounter library and also selected a different board to compile to. I now have the code compiled.
This was my first time on the forum and I have learnt a few things, like you can copy the complete error message (I think I said early on that I am a novice at code)
Again, thanks for your time and hopefully when I get my buffer and pre-scaler board together I will have a working counter for my project.
rod411964:
