Frequency counter problem at low frequency
I have a frequency counter code using pulseIn command. It's measuring a sweeping frequency, so 20 pulses at 1hz 20 at 2 hz to 20 at 6 hz. These all have a 10% duty cycle
I'm using Ltime to measure the low time and Htime to measure the high time.
The problem I have is for the 1hz and 2 hz the Ltime is measuring 0.0 , the high time measures correctly . The low time for the other frequencies measures fine.
the consiquence of this is the 1hz is displayed as 10hz and the 2hz displayed as 20 hz.
#include <LiquidCrystal.h>
LiquidCrystal lcd(7,6,5,4,3,2);
unsigned long Htime;
float Ltime;
float Ttime;
float frequency;
float hightime;
pinMode(8,INPUT);
lcd.begin(16,2);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Frquency ");
Htime=pulseIn(8,HIGH);
Ltime=pulseIn(8,LOW),
Ttime=Htime+Ltime;
frequency=(1000000)/Ttime;
lcd.setCursor(2,2);
lcd.print(frequency);
lcd.print("  Hz");
delay(2000);
What type does pulseIn() return? Why are you storing the value in a different type?
What is the DOCUMENTED resolution of pulseIn() in the units it returns?
Where is your proof?
It is not easy to measure low and high frequencies with the same code.
There are two good libraries, here is the difference: www.pjrc.com/teensy/td_libs_FreqMeasure.html#compare
I replaced the "frequency" with Htime and then Ltime so that I could read ms it was measuring and for 1hz and 2 hz the Ltime came back as 0.0
Problem solved.
I added a long timeout on the Ltime function
Ltime=pulseIn(8,LOW,100000000)
it works perfectly now
