Frequency generator/resonator - Help needed!
Hello everybody!
I need help with my new project.
I want to use arduino to,
  • generate a frequency in a range of 500hz to 20khz
  • read an analog voltage
  • search this whole range to find the frequency that gives the higher voltage to analog input, and lock into this frequency for 10sec
    I have included arduinOSC library which is a very simple and stable square wave generator.
Here is my code:
#include <arduinOSC.h>
 int freq = 500;
 int goodf= 0;
 int senspin = A0;
 int volt = 1;
 int voltmax = 0;
 boolean lock = false;
  arduinOSC::initOSC(WAVEFORM_SQUARE);
  pinMode(senspin, INPUT);
 if (lock==false)
  for (freq=500; freq==20000; freq++)
     arduinOSC::setOSCFrequency(freq);
     if (voltmax < volt)
       voltmax = volt;
       volt = analogRead(senspin);
       lock = true;
       goodf = freq;
       arduinOSC::setOSCFrequency(goodf);
      delay(50);
else {
lock=false;
delay(10000);
when i run this code on my Leonardo, I get an output frequency on pin 9 but it doesen’t change as I higher the voltage.
any help would be greatful.
Thanks in advance…!!
Zis :slight_smile:
arduinosc_0.1.zip (15.6 KB)
Why are there no Serial.begin() and Serial.print() statements in the code?
What is supplying the voltage that you think you are measuring?
     if (voltmax < volt)
       voltmax = volt;
You are performing a comparison, then an assignment, then a read. Looks like completely the wrong order of operations to me.
this line : ** for (freq=500; freq==20000; freq++)** looks wrong. should be freq<=20000
Thanks everybody for helping,
I came up with a code that is working.
But there are some debugging that i can’t make them work properly.
the new code is this:
#include <LiquidCrystal.h>
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);
 int hz = 500;
 int freq= 0;
 int volt = 0;
 int vmax = 0;
 lcd.begin(16, 2);
 lcd.setCursor(0,0);
  //Serial.begin(9600);
 pinMode(A0, INPUT);
  volt = analogRead(A0);
 // vmax = 0;                //use if you want to set a new lock frequency each time
  for (hz=3000; hz<=20000; hz++)
     arduinOSC::setOSCFrequency(hz);
     delay(1);
     if (vmax < volt)
       vmax = volt;
       freq = hz;
    //Serial.println(vmax);
    //Serial.println(freq);
   lcd.setCursor(1,0);
   lcd.print(freq);
   delay(10000);
But… lcd.print() or other lcd functions do not work at all in the loop(in setup works)
also… Serial.flush() does not work. My serial screen fills up with my output
any ideas??
Thanks
delay(10000); is your problem .
astrofrostbyte:
Thanks for your reply,
The problem is not the delay function...
The arduinOSC.h library conflicts with LiquidCrystal.h.... once I comment the oscillator library and lines the LCD prints everything well...
I think i might need an other library to use or an external synthesizer shield... 8) :slight_smile:
