Nooo ofcourse not, I used an Arduino!
As you can read on that page the AVR used is an ATmega8 so the software is compatible with an arduino. Used avrstudio to write the code and uploaded the .hex to the arduino.
Quick and Dirty Code
// AVR FFT
// based on code from ELM-chan & Michael Spiceland
// Designed for atmega328 @ 16MHz
// LCD Pins for Arduino Data(DB0-Pin2|DB1-Pin3|DB2-Pin4|DB3-Pin5) Funtions(RS-Pin6|RW-Pin7|E-Pin8)
// Samplerate = 9.6kHz Max Freq ~5kHz
// (c) Peeter123
// F_CPU is defined already in project definition
// #define F_CPU 16000000
#include <avr/io.h>
#include <avr/pgmspace.h>
#include <avr/interrupt.h>
#include <avr/eeprom.h>
#include <avr/sleep.h>
#include <stdio.h>
#include <inttypes.h>
#include <ctype.h>
#include <util/delay.h>
#include <math.h>
#include "fft.h"
#include "lcd.h"
// choose 9600 if you have issues, but you shouldn't
#define BAUD 38400
#define MYUBRR F_CPU/16/BAUD-1
/* defines */
#define NUM_SAMPLES FFT_N
#define FFT_SIZE FFT_N / 2
int16_t capture[FFT_N]; /* Wave capturing buffer */
complex_t bfly_buff[FFT_N]; /* FFT buffer */
uint16_t spectrum[FFT_N/2]; /* Spectrum output buffer */
// UART functions
static int uart_putchar(char c, FILE *stream);
uint8_t uart_getchar(void);
static FILE mystdout = FDEV_SETUP_STREAM(uart_putchar, NULL, _FDEV_SETUP_WRITE);
// make blinkin' e-z on port C
void BlinkMS(int time);
int set_PORTB_bit(int position, int value);
void lcd_spectrum_data(unsigned char fft_hight, unsigned char position);
// to print FFT data to UART
void print_FFT(uint16_t *buffer, uint8_t points);
void print_wave(int16_t *buffer, uint8_t points);
static const PROGMEM unsigned char BarGraphChar[] = //Bargraph custom chars
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1f,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1f, 0x1f,
0x0, 0x0, 0x0, 0x0, 0x0, 0x1f, 0x1f, 0x1f,
0x0, 0x0, 0x0, 0x0, 0x1f, 0x1f, 0x1f, 0x1f,
0x0, 0x0, 0x0, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f,
0x0, 0x0, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f,
0x0, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f
unsigned char LcdDataBuffer1[20]; //LCD Line data buffers
unsigned char LcdDataBuffer2[20];
unsigned char LcdDataBuffer3[20];
unsigned char LcdDataBuffer4[20];
* ISR TIMER0 Overflow
* This routine is run evertime the timer counter overflows. Since the
* timer counter is 8 bits, it can count to 255 before overflowing and
* going back to 0. The frequency this is executed in is determined by
* the clock speed / clk_divide (TCCR0) / 256.
ISR(TIMER0_OVF_vect){
static unsigned char count = 0;
static unsigned char count_clock = 0;
static uint16_t offset = 0;
uint8_t adc_val;
//printf("%s \n ","inside interrupt");
// we only want to run every clk/4 times 8mhz
count_clock++;
if ((count_clock % 4)){ // 2 = 16mhz, 4 = 8mhz, 8 = 4mhz
return;}
ADCSRA |= (1 << ADSC); // start ADC conversion
while (ADCSRA&(1<<ADSC)); // wait for the result to be available
adc_val = ADCH;
capture[offset] = ((int16_t)(adc_val)-127)*4; // convert to signed linear and multiplied by 4
offset++;
if (offset == NUM_SAMPLES) // buffer is full
count = 0;
//FFT
fft_input(capture, bfly_buff);
fft_execute(bfly_buff);
fft_output(bfly_buff, spectrum);
print_FFT(spectrum, NUM_SAMPLES/2);
offset = 0;
//LCD
lcd_clrscr();
for(unsigned char p=0;p<60;p = p + 3){
lcd_spectrum_data(spectrum[p+1],count);
count++;
for(unsigned char l1=0;l1<20;l1++){
lcd_putc(LcdDataBuffer1[l1]);
lcd_gotoxy(0,1);
for(unsigned char l2=0;l2<20;l2++){
lcd_putc(LcdDataBuffer2[l2]);
lcd_gotoxy(0,2);
for(unsigned char l3=0;l3<20;l3++){
lcd_putc(LcdDataBuffer3[l3]);
lcd_gotoxy(0,3);
for(unsigned char l4=0;l4<20;l4++){
lcd_putc(LcdDataBuffer4[l4]);
int main(void){
// STARTUP SEQUENCE
/* initialize port data directions */
PORTB = 0xFF;
/* initialize timers */
TCCR0B |= _BV(CS00); // clk prescale (Fcpu/1)
TIMSK0 |= _BV(TOIE0); // enable timer/counter0 overflow interrupt
TCNT0 = 0; // Reset timer 0
//TCCR1B |= (1 << WGM12); // Configure timer 1 for CTC mode
//TCCR1A |= (1 << COM1A0);// Enable timer 1 Compare Output channel A in toggle mode
//OCR1A = 31; // Set CTC compare value to 500kHz at 16MHz AVR clock, with a prescaler of 1
//TCCR1B |= (1 << CS00); // Start timer at Fcpu/1
/* initialize the ADC */
ADMUX |= _BV(REFS0)| _BV(ADLAR); // we only want 8-bit on ADC 0 VCC reference
ADCSRA |= _BV(ADEN); // for now we don't do this in the ISR | _BV(ADIE);
ADCSRA |= _BV(ADPS2)| _BV(ADPS0);//_BV(ADPS2);//| _BV(ADPS1)| _BV(ADPS0); // clk is / 32
/* initialize the UART */
DDRD = 0b11111110; //PORTD (RX on PD0)
// load baud rate registers
UBRR0H = (MYUBRR) >> 8;
UBRR0L = MYUBRR;
// enable transmitter + receiver
UCSR0B = (1<<RXEN0)|(1<<TXEN0);
// asynchronous, no parity, 1 stop bit, 8 bit character size
UCSR0C = (0<<UMSEL01)|(0<<UMSEL00)|(0<<UPM01)|(0<<UPM00)|(0<<USBS0)|(0<<UCSZ02)|(1<<UCSZ01)|(1<<UCSZ00);
stdout = &mystdout;
/* initialize the LCD Display*/
lcd_init(LCD_DISP_ON);
//Load two userdefined characters from program memory into LCD controller CG RAM
lcd_command(_BV(LCD_CGRAM)); /* set CG RAM start address 0 */
for(unsigned char i=0; i<64; i++)
lcd_data(pgm_read_byte_near(&BarGraphChar[i]));
// let ya know startup's finished
BlinkMS(500);
sei(); //enable global interrupts
/* AVR's like to have a loop */
while(1) {
void lcd_spectrum_data(unsigned char fft_hight, unsigned char position){
if(fft_hight < 32){
LcdDataBuffer1[position] = 0;
LcdDataBuffer2[position] = 0;
LcdDataBuffer3[position] = 0;
LcdDataBuffer4[position] = 1 + fft_hight / 4;
}else if(fft_hight < 64){
LcdDataBuffer3[position] = fft_hight / 4;
LcdDataBuffer4[position] = 0xFF;
}else if(fft_hight < 96){
LcdDataBuffer1[position] = fft_hight / 4;
LcdDataBuffer2[position] = 0xFF;
LcdDataBuffer3[position] = 0xFF;
}else if(fft_hight < 128){
}else{
LcdDataBuffer1[position] = 0xFF;
if (c == '\n') uart_putchar('\r', stream);
loop_until_bit_is_set(UCSR0A, UDRE0);
UDR0 = c;
return 0;
while( !(UCSR0A & (1<<RXC0)) );
return(UDR0);
// Blink an LED on PB5 Pin 13 Arduino
set_PORTB_bit(5, 1);
_delay_ms(time);
set_PORTB_bit(5, 0);
_delay_ms(time);
// Sets or clears the bit in position 'position'
// either high or low (1 or 0) to match 'value'.
// Leaves all other bits in PORTB unchanged.
if (value == 0){
PORTB &= ~(1 << position); // Set bit # 'position' low
else{
PORTB |= (1 << position); // Set bit # 'position' high
return 1;
#define GAIN 1
// prints comma separated values of sample[0]...sample[N/2] to UART
uint8_t i = 0;
uint16_t value;
for(i = 0; i < points; i++)
value = (unsigned char)(buffer[i]) * GAIN;
// I print the value of the FFT sample
printf("%d,",buffer[i]);
// end
printf("\n");
