Frequency Measurement of a Guitar String.
Hi everybody,
So recently I have been using a frequency library to measure the frequency of a guitar string. I have wired up a guitar pickup to a 4th order low pass filter to isolate the fundamental frequency of the string. The signal then is passed through a comparator and finally to a voltage regulator. The end result is a square with a maximum voltage of 4V.
Here’s the link to the library if you are interested: FreqMeasure Library, for Measuring Frequencies in the 0.1 to 1000 Hz range, or RPM Tachometer Applications
Here is the code:
#include <FreqMeasure.h>
  Serial.begin(57600);
  FreqMeasure.begin();
double sum=0;
int count=0;
  if (FreqMeasure.available()) {
    sum = sum + FreqMeasure.read();
    count = count + 1;
    if (count > 30) {
      float frequency = FreqMeasure.countToFrequency(sum / count);
      Serial.println(frequency);
      sum = 0;
      count = 0;
Now the code works fine if the frequency is constant (e.g. input a frequency from a function generator). However, when I test it on the guitar I get a range of frequencies. Anything below 80 Hz is due to the transient nature of the string.
I want to add code so that the Arduino can pick out those 80 Hz as seen in the image and ignore all other printed values. I have attached the image below.
Any help would be greatly appreciated.
Thanks.
Maybe average 10 readings, throwing out any data points more than 10% below the current average?
   float average = getFrequency();
   for (int i=1; i<=10; ) {
      float frequency = getFrequency();
      if (frequency < (0.9 * (average/i)))
           continue;  // Skip this sample
      average += frequency;
     i++;
Have you researched FFT with arduino ?
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GPCK_enUS504US504&ion=1&espv=2&ie=UTF-8#q=fft%20with%20arduino
