frequency measurement with small problem
This is my first project with Arduino and everything went well, almost 100%... but then...
My project deals with frequency measurement(Thanks to Martin Nawrath Lab3) As the architecture of the ATMEGA chip it provides a special counter and capture unit and the frequency detection is done with this way with high precision.
My actual problem is that after detecting for example three different frequencies the reset (false) function does not work properly.After the first run when all three tone are detected LED goes HIGH as it should be but after that it takes only two tone sample and LED goes HIGH again. Somehow the code remember the last state and the false function does not reset all three flag. I have tried to solve this without success.
Any idea?
 for (i=0;i<3;i++){
   if(lfrq >=315 and lfrq <=325 ){ //320
    tone1=true; }
   for (i=0;i<3;i++){
   if(lfrq >=365 and lfrq <=375 ){ //370
    tone2=true; }
   for (i=0;i<3;i++){
   if(lfrq >=415 and lfrq <=425 ){ //420
    tone3=true; }
   if (tone1==true&&tone2==true&&tone3==true){
  digitalWrite(led12,HIGH);
  delay(200);
  digitalWrite(led12, LOW);
  tone1=false;
  tone2=false;
  tone3=false;
Probably need to post the whole code. But first Auto Format (ctrl-T). It appears there are too many curly braces in what you posted, so it's almost impossible to tell what control flow is intended or obtained :slight_smile:
Seconded.
johncc:
It says "No changes necessary for Auto Format"
So this is whole code with my mods javascript:void(0);
 #include "FreqPeriod.h"
double lfrq;
long int pp;
int led12=12;
int i;
int tone1;
int tone2;
int tone3;
  for (i=0;i<3;i++);
  pinMode(led12,OUTPUT);
  FreqPeriod::begin();
  Serial.println("FreqPeriod Library Test");
  pp=FreqPeriod::getPeriod();
  if (pp ){
    Serial.print("period: ");
    Serial.print(pp);
    Serial.print(" 1/16us  /  frequency: ");
    lfrq= 16000400.0 / pp;
    printDouble(lfrq,6);
    Serial.print(" Hz");
    Serial.println("  ");
    for (i=0;i<3;i++){
        tone1=true;
    for (i=0;i<3;i++){
        tone2=true;
    for (i=0;i<3;i++){
        tone3=true;
      delay(200);
      tone1=false;
      tone2=false;
      tone3=false;
void printDouble( double val, byte precision){
  // prints val with number of decimal places determine by precision
  // precision is a number from 0 to 6 indicating the desired decimial places
  // example: lcdPrintDouble( 3.1415, 2); // prints 3.14 (two decimal places)
  if(val < 0.0){
    Serial.print('-');
    val = -val;
  Serial.print (int(val));  //prints the int part
  if( precision > 0) {
    Serial.print("."); // print the decimal point
    unsigned long frac;
    unsigned long mult = 1;
    byte padding = precision -1;
    while(precision--)
      mult *=10;
    if(val >= 0)
      frac = (val - int(val)) * mult;
      frac = (int(val)- val ) * mult;
    unsigned long frac1 = frac;
    while( frac1 /= 10 )
      padding--;
    while(  padding--)
      Serial.print("0");
    Serial.print(frac,DEC) ;
for (i=0;i<3;i++);
First problem
        tone2=true;
Another, probably.
AWOL:
for (i=0;i<3;i++);
First problem
tone2=true;
Another, probably.
The problem remains the same even if I removed the whole (for loop), LED goes HIGH still after two sample. The meaning (for loop) was ensure an adequate number of samples.
        tone2=true;
This this should be OK anyway
Do you know what a "break" does?
Why are you always breaking on the first iteration of the for loop?
If you do that, you may as well not have the loop.
Yeah, all of your for loops in setup() and loop() functions are incorrect and are not doing anything.
But,
you could put a print in to convince yourself that the booleans are getting reset
      tone1=false;
      tone2=false;
      tone3=false;
      Serial.print(tone1);Serial.print(tone2); Serial.println(tone3);
and
what is your output of lfrq at the time that tone3 is improperly going true?
backlight:
What is 'and' supposed to do?
Are you being serious?
It says;
period: 43189 1/16us  /  frequency: 370.473968 Hz
period: 43178 1/16us  /  frequency: 370.568359 Hz
period: 43179 1/16us  /  frequency: 370.559753 Hz
period: 43181 1/16us  /  frequency: 370.542602 Hz
period: 108264528 1/16us  /  frequency: 0.147789 Hz
period: 20586 1/16us  /  frequency: 777.246643 Hz
period: 38081 1/16us  /  frequency: 420.167541 Hz
period: 38131 1/16us  /  frequency: 419.616577 Hz
period: 38039 1/16us  /  frequency: 420.631469 Hz
period: 38048 1/16us  /  frequency: 420.531951 Hz
period: 38035 1/16us  /  frequency: 420.675689 Hz
period: 38040 1/16us  /  frequency: 420.620391 Hz
period: 38047 1/16us  /  frequency: 420.542999 Hz
period: 38050 1/16us  /  frequency: 420.509857 Hz
period: 38049 1/16us  /  frequency: 420.520904 Hz
period: 38051 1/16us  /  frequency: 420.498809 Hz
period: 38029 1/16us  /  frequency: 420.742065 Hz
period: 38021 1/16us  /  frequency: 420.830596 Hz
period: 38041 1/16us  /  frequency: 420.609344 Hz
As you can see there is sometimes transition (glitch) on frequency at start but it is out of range and rest of sample is steady.Problem stays same if I add sample frequencies to five or even 7,after second run LED goes high after four for (five) and six for (seven) sample.
I removed for() loop and my code stands now;
 double lfrq;
 long int pp;
 int led12=12;
 int tone1;
 int tone2;
 int tone3;
  if (pp ){
    Serial.print(pp);
   if(lfrq >=315 && lfrq <=325 ){ //320
    tone1=true; }
   if(lfrq >=365 && lfrq <=375 ){ //370
    tone2=true; }
   if(lfrq >=415 && lfrq <=425 ){ //420
    tone3=true; }
  delay(200);
  tone1=false;
  tone2=false;
  tone3=false;
  if(val < 0.0){
    Serial.print('-');
    val = -val;
    unsigned long frac;
    while(precision--)
      mult *=10;
    if(val >= 0)
      padding--;
    while(  padding--)
      Serial.print("0");
backlight:
The important part is the print of the samples immediately before the led comes when you don't think it should (and when you get the output from Serial.print( tone1 ton2 tone3). Can you capture that, examine, and post?
John
johncc:
backlight:
John
After I added the Serial.print( tone1 tone2 tone3) to code now it says something strange. It sets the first sample of the third frequency (420Hz) like above(before) tone1,tone2,tone3 false(000) Why it is doing that?
period: 43193 1/16us  /  frequency: 370.439666 Hz
period: 43186 1/16us  /  frequency: 370.499694 Hz
period: 43173 1/16us  /  frequency: 370.611267 Hz
period: 113674601 1/16us  /  frequency: 0.140756 Hz
period: 20585 1/16us  /  frequency: 777.284423 Hz
period: 38078 1/16us  /  frequency: 420.200653 Hz
000
period: 38045 1/16us  /  frequency: 420.565124 Hz
period: 38052 1/16us  /  frequency: 420.487762 Hz
period: 38031 1/16us  /  frequency: 420.719940 Hz
period: 38046 1/16us  /  frequency: 420.554077 Hz
period: 38034 1/16us  /  frequency: 420.686767 Hz
period: 38037 1/16us  /  frequency: 420.653564 Hz
period: 38044 1/16us  /  frequency: 420.576171 Hz
period: 38036 1/16us  /  frequency: 420.664642 Hz
period: 38038 1/16us  /  frequency: 420.642517 Hz
backlight:
000
...lots more
I'm not sure if I understand your question, but...(working backwards)
The 000 prints out when you have just reset all three flags to false, hence 000.
Right before that the led blinked for about .2 seconds.
Right before you set them to false all three were true, since it entered the if(tone1==tone2==tone3==true) code
Right before that was the first time tone3 was true because it was the first 420.
Sometime before that it had already seen 320 and 370 (we assume this but it's prior to your posted log)
By "Right before that" I mean micro maybe nano seconds.
So far I don't see anything amiss? Were you not expecting that there should be a 420mhz coming across at that time? (I have no idea about that library or where these frequencies are coming from or generated :slight_smile: )
John
Any idea?
The code makes zero sense.
For example, I reformatted the first piece like this:
 for (i=0;i<3;i++){
      tone1=true;
What exactly did you expect it to do?
The code he is currently using is in Reply #10, have a look...
    tone1=true; }
    tone2=true; }
    tone3=true; }
  delay(200);
  tone1=false;
  tone2=false;
  tone3=false;
I would use more parenthesis to be sure of operation order and just for clarity and use the AutoFormat tool also for clarity.
That last line of code above... how about printing "flags reset"?
I looked at the library
  FreqPeriod
  Counter1 unit capturing analog comparator event measuring period length of analog signal on input AIN1
  AIN0 set to VCC/2 by resistors
  pin5 used as output for comparator feedback
  Analog comparator interrupt service is used to calculate period length
  Timer1 overflow interrupt service used to count overflow events
I don't speak AVR-interrupt-port-speak though. Could there be a problem/conflict with his writing to LED on Arduino pin 12? He says it always misbehaves on the "second time around".
Backlight, what kind of Arduino do you have exactly?
John
GoForSmoke:
Clarity, ok. But which operation order are you unsure of?
"000" is Backlightian for "flags reset". Scan from the top of the thread for that backstory :slight_smile:
Agree with that. Here, I am involved enough already I will do it for him/you
double lfrq;
long int pp;
int led12 = 12;
int tone1;
int tone2;
int tone3;
	pinMode(led12, OUTPUT);
	pp = FreqPeriod::getPeriod();
	if (pp) {
		Serial.print(pp);
		lfrq = 16000400.0 / pp;
		printDouble(lfrq, 6);
		if (lfrq >= 315 && lfrq <= 325) { //320
			tone1 = true;
		if (lfrq >= 365 && lfrq <= 375) { //370
			tone2 = true;
		if (lfrq >= 415 && lfrq <= 425) { //420
			tone3 = true;
		if (tone1 == true && tone2 == true && tone3 == true) {
			digitalWrite(led12, HIGH);
			delay(200);
			tone1 = false;
			tone2 = false;
			tone3 = false;
void printDouble(double val, byte precision) {
	if (val < 0.0) {
		Serial.print('-');
		val = -val;
	Serial.print(int(val));  //prints the int part
	if (precision > 0) {
		unsigned long frac;
		byte padding = precision - 1;
		while (precision--)
			mult *= 10;
		if (val >= 0)
			frac = (int(val) - val) * mult;
		while (frac1 /= 10)
			padding--;
		while (padding--)
			Serial.print("0");
		Serial.print(frac, DEC);
000
...lots more
OK
I think I understand now how the code works. Whether it would be possible that it toggle tone3 to back true right after all three flags has gone false.I mean that (period: 38045 1/16us / frequency: 420.565124 Hz) right after 000 (false) fires tone3 flag true and after that when second run comes, it needs only freq 370 and freq 320 to light up LED.
How I can prevent this toggle, my actual need is still three sample every round?
I added Serial .print to read tone3=true and I think it toggles back.What do you think?
    tone3=true; }
  Serial.print(tone3); // This is for testing purpose only
  delay(200);
  tone1=false;
  tone2=false;
  tone3=false;
  /*Serial.print(tone1);Serial.print(tone2);*/ Serial.println(tone3);
Now it says;
0period: 43188 1/16us  /  frequency: 370.482543 Hz
0period: 43186 1/16us  /  frequency: 370.499694 Hz
0period: 43171 1/16us  /  frequency: 370.628418 Hz
0period: 83224463 1/16us  /  frequency: 0.192255 Hz
0period: 20585 1/16us  /  frequency: 777.284423 Hz
0period: 38081 1/16us  /  frequency: 420.167541 Hz
10
1period: 38049 1/16us  /  frequency: 420.520904 Hz
1period: 38034 1/16us  /  frequency: 420.686767 Hz
1period: 38047 1/16us  /  frequency: 420.542999 Hz
1period: 38036 1/16us  /  frequency: 420.664642 Hz
