Frequency Messure
Hi There.
I am using an Uno to measure frequency on a motor, and then print on the Serial monitor. I am using the FreqMeasure library and i works fine, but when motor stops Serial monitor shows last measured frequency. How do I get it to show “0” with some simple code?
Here’s a link to the library.
Thanks.
#include <FreqMeasure.h>
  Serial.begin(57600);
  FreqMeasure.begin();
double sum=0;
int count=0;
  if (FreqMeasure.available()) {
    // average several reading together
    sum = sum + FreqMeasure.read();
    count = count + 1;
    if (count > 30) {
      float frequency FreqMeasure.countToFrequency(sum / count);
      Serial.println(frequency);
      sum = 0;
      count = 0;
Here's a link to the library.
Where's your code?
Updated with code, Sorry..
How do I get it to show "0" with some simple code?
Add an else clause to this if:
...though you may only want to do that after a timeout.
AWOL
Could you elaborate how to do this ? Thanks
Set a variable to the current value of millis() each time you get a valid reading.
Compare that time to the current time when you're not getting valid readings, and take appropriate action
