I am making a project to heat a heater using thyristor, it is working fine, but the only problem is the frequency.
when i give a frequency of 1 Hz in the Pulse R3(2) the curve is perfect, but when i change the frequency to 50 Hz, the curve become disturbed, and unfortunately i want to use the frequency of 50 Hz.
jremington:
What, exactly is doing the heating ("L1")?
the heater in the circuit is the Lamp , ( to see if it will shine or no ) , the pulse R3(2) [ 230V and 1Hz] is giving a pulse that goes throught the zero crossing detector (its pulse is in green), then i send the output to arduino to analog A0, and give back a pulse from the output pin 13 to the thyristor , the output pulse is in yellow
webtuto:
I'm not sure what you're expecting, but that's how thyristors work. You can't do high speed PWM with them, everything is based on the timing of the zero crossings. Phase angle control is going to cause the output waveform to be significantly distorted.
Jiggy-Ninja:
so is there something i have to change to be able to use the 50 Hz frequency ?
Your circuit looks hazardous as there is no isolation between the Arduino and the mains. This could have lethal consequences. Depending on the neutral side to be grounded is not an acceptable solution.
I tried to follow your guidelines and i come up with the circuit im attaching
the arduino code i used is
int AC_LOAD = 9; // Output to Opto Triac pin
int dimming = 128; // Dimming level (0-128) 0 = ON, 128 = OFF
pinMode(AC_LOAD, OUTPUT);// Set AC Load pin as output
attachInterrupt(0, zero_crosss_int, RISING); // Choose the zero cross interrupt # from the table above
//the interrupt function must take no parameters and return nothing
void zero_crosss_int() //function to be fired at the zero crossing to dim the light
// Firing angle calculation : 1 full 50Hz wave =1/50=20ms
// Every zerocrossing thus: (50Hz)-> 10ms (1/2 Cycle)
// For 60Hz => 8.33ms (10.000/120)
// 10ms=10000us
// (10000us - 10us) / 128 = 75 (Approx) For 60Hz =>65
int dimtime = (75*dimming); // For 60Hz =>65
delayMicroseconds(dimtime); // Wait till firing the TRIAC
digitalWrite(AC_LOAD, HIGH); // Fire the TRIAC
delayMicroseconds(10); // triac On propogation delay (for 60Hz use 8.33)
digitalWrite(AC_LOAD, LOW); // No longer trigger the TRIAC (the next zero crossing will swith it off) TRIAC
for (int i=5; i <= 128; i++){
dimming=i;
delay(10);
but the output (the yellow wave) is not what im aiming for .
the first problem is that it is cutting only the positive wave
the second problem is that the angle of cutting change
