Frequency
Hey guys,
this is probably an easy fix but i'm having problems with it. The problem is:
float frequency = (1);
I am trying the reduce the freq. to around 0.5 however when I set it, it does not show the sweeper.
I'll explain, the project is as many have done, a radar screen. The sweeper is moving too fast, I would prefer to slow it down however i'm not quite sure how to do it.
Any advice or help would be appreciated.
Thankyou,
  • Dan
Try here
// -------------------------------------------- RADAR ---------------------------------------------------
// ------------------------------ SERIAL PRINT (ARDUINO TO PROCESSING) ----------------------------------
//Program Variables
float xcoord, ycoord, xcoord2, ycoord2; //x and y coordinates
int angle;
int angle2;
// ---------------------------------------- RADAR SWEEPER -----------------------------------------------
float radius = 500; // Radius of radar sweep
float hyp = 500; // sweep arm length
float frequency = (1); //speed of sweep default = 1 (is it possible to lower the frequency?????)
int sweep = 0; // 0 = anti-clockwise 1 = clockwise
// FONT
PFont myFont;// uses a library to create font
// ------------------------------------- WINDOW SIZE & FONT ---------------------------------------------
// SETUP WINDOW AND FONT
void setup(){
size(1000, 500); // Window size
myFont = createFont("Verdana", 20); // System font
textFont(myFont);}
// ----------------------------------- WINDOWS BACKGROUND COLOUR ----------------------------------------
void draw(){
background (#00569B); // Window background colour
noStroke();
fill(255); // Length of vertical line
smooth();
// -------------------------------------- BEGINNING OF CIRCLES ------------------------------------------
ellipse(width/2, 500, radius2, radius2); // Position of circles
stroke(180); // How dark the line is
fill(250);
smooth();
ellipse(width/2, 500, (radius2)-100, (radius2)-100);
stroke(180);
fill(245);
smooth();
ellipse(width/2, 500, (radius2)-200, (radius2)-200);
stroke(180);
fill(240);
smooth();
ellipse(width/2, 500, (radius2)-300, (radius2)-300);
stroke(180);
fill(235);
smooth();
ellipse(width/2, 500, (radius2)-400, (radius2)-400);
stroke(180);
fill(230);
smooth();
ellipse(width/2, 500, (radius2)-500, (radius2)-500);
stroke(180);
fill(225);
smooth();
ellipse(width/2, 500, (radius2)-600, (radius2)-600);
stroke(180);
fill(220);
smooth();
ellipse(width/2, 500, (radius2)-700, (radius2)-700);
stroke(180);
fill(215);
smooth();
ellipse(width/2, 500, (radius2)-800, (radius2)-800);
stroke(180);
fill(210);
smooth();
ellipse(width/2, 500, (radius2)-900, (radius2)-900);
stroke(180);
line(width/2, 500, 500, 0);
stroke(180);
// ---------------------------------------- END OF CIRCLES ----------------------------------------------
// ------------------------------------------- SWEEPER --------------------------------------------------
// ROTATES LINE AROUND CIRCLE
xcoord = radius + cos(radians(angle))*hyp;
ycoord = radius + sin(radians(angle))*hyp;
stroke(#FF0011); // default = 1 (BLACK)
line(width/2, 500, xcoord, ycoord); // Set position of sweep point
// ------------------------------------------ CALCULATIONS ----------------------------------------------
// keep reinitializing to 0, to avoid flashing during redrawing
angle2 = 0;
if(sweep == 0)
angle -= frequency;
else if(sweep == 1) // 1 = repeats 0 = moves once
angle += frequency;
if(angle == 0)
sweep = 0;
else if(angle == -180) //At 180 degrees, the sweeper stops and goes back (default = -180)
sweep = 1; // 1 = repeats 0 = 0-360°+ (default = 1)
// --------------------------------------------- TEXT ---------------------------------------------------
// TEXT ONLY
text("Radar Example", 20, 30); // Last co-ordinates are to set position of text
text("Sweep Angle = "+angle, 790, 30); // Co-ordinates for text
text("x = "+xcoord, 790, 55); // x axis position
text("y = "+ycoord, 790, 75); // y axis position
OK, just a couple of points.
When you read the thread I linked, you missed the bit about putting code between tags (there are really good reasons for this).
The other is, you posted Processing code. This is the Arduino site.
Why are there parentheses around the value?
How do you propose to subtract a float from an int and get something other than an int?
