FrequencyTimer2.cpp error
i need help i cant get FrequencyTimer2.cpp to work ive tried all the steps in a few forums here and still nothing im using arduino-0017 and a arduino mega id like to get my LED matrix working with the test code they have like the life code please help thanks
 * Show messages on an 8x8 led matrix,
 * scrolling from right to left.
 * Uses FrequencyTimer2 library to
 * constantly run an interrupt routine
 * at a specified frequency. This
 * refreshes the display without the
 * main loop having to do anything.
#include <FrequencyTimer2.h>
#define SPACE { \
    {0, 0, 0, 0, 0, 0, 0, 0},  \
    {0, 0, 0, 0, 0, 0, 0, 0} \
#define H
    {0, 1, 0, 0, 0, 0, 1, 0}, \
    {0, 1, 1, 1, 1, 1, 1, 0}, \
    {0, 1, 0, 0, 0, 0, 1, 0}  \
#define E  { \
    {0, 1, 0, 0, 0, 0, 0, 0}, \
    {0, 1, 1, 1, 1, 1, 1, 0}  \
#define L { \
#define O { \
    {0, 0, 0, 1, 1, 0, 0, 0}, \
    {0, 0, 1, 0, 0, 1, 0, 0}, \
    {0, 0, 0, 1, 1, 0, 0, 0}  \
byte col = 0;
byte leds[8][8];
// pin[xx] on led matrix connected to nn on Arduino (-1 is dummy to make array start at pos 1)
int pins[17]= {-1, 22, 23, 24, 25, 26, 27, 28, 29, 40, 41, 42, 43, 44, 45, 46, 47};
// col[xx] of leds = pin yy on led matrix
int cols[8] = {pins[22], pins[23], pins[24], pins[25], pins[26], pins[27], pins[28], pins[29]};
// row[xx] of leds = pin yy on led matrix
int rows[8] = {pins[40], pins[41], pins[42], pins[43], pins[44], pins[45], pins[46], pins[47]};
const int numPatterns = 6;
byte patterns[numPatterns][8][8] = {
  H,E,L,L,O,SPACE
int pattern = 0;
  // sets the pins as output
  for (int i = 1; i <= 16; i++) {
    pinMode(pins[i], OUTPUT);
  // set up cols and rows
  for (int i = 1; i <= 8; i++) {
    digitalWrite(cols[i - 1], LOW);
    digitalWrite(rows[i - 1], LOW);
  clearLeds();
  // Turn off toggling of pin 11
  FrequencyTimer2::disable();
  // Set refresh rate (interrupt timeout period)
  FrequencyTimer2::setPeriod(2000);
  // Set interrupt routine to be called
  FrequencyTimer2::setOnOverflow(display);
  setPattern(pattern);
    pattern = ++pattern % numPatterns;
    slidePattern(pattern, 60);
void clearLeds() {
  // Clear display array
  for (int i = 0; i < 8; i++) {
    for (int j = 0; j < 8; j++) {
      leds[i][j] = 0;
void setPattern(int pattern) {
      leds[i][j] = patterns[pattern][i][j];
void slidePattern(int pattern, int del) {
  for (int l = 0; l < 8; l++) {
    for (int i = 0; i < 7; i++) {
        leds[j][i] = leds[j][i+1];
      leds[j][7] = patterns[pattern][j][0 + l];
    delay(del);
// Interrupt routine
void display() {
  digitalWrite(cols[col], LOW);  // Turn whole previous column off
  col++;
  if (col == 8) {
    col = 0;
  for (int row = 0; row < 8; row++) {
    if (leds[col][7 - row] == 1) {
      digitalWrite(rows[row], LOW);  // Turn on this led
    else {
      digitalWrite(rows[row], HIGH); // Turn off this led
  digitalWrite(cols[col], HIGH); // Turn whole column on at once (for equal lighting times)
FrequencyTimer2.cpp:35: error: expected unqualified-id before '{' token
#define H
You have #define'd H as nothing, then you have a block of characters that don't mean anything to the compiler, so it complains.
Compare this code to that of the #define's SPACE above it, or the #define'd E after it. The { needs to be on the same line as the #define statement, or there needs to be a .
